How do you use format - Printable Version
+--- Thread: How do you use format (/thread-6475.html)
How do you use format - StephenG1CMZ - 06-29-2016 09:41 PM
How do you use format to format numbers into strings?
EXPORT HOWFMT()
 MSGBOX(format(9.3456,"s3"));
Gives a bad argument error.
RE: How do you use format - Joe Horn - 06-29-2016 10:12 PM
(06-29-2016 09:41 PM)StephenG1CMZ Wrote:  How do you use format to format numbers into strings?
The format command is a CAS command which Home doesn't know how to handle. So use CAS(format(9.3456,"s3")) when using it in a non-CAS program.
RE: How do you use format - roadrunner - 06-29-2016 10:14 PM
Try:
EXPORT HOWFMT()
MSGBOX(format(9.3456,QUOTE("s3")));
-road
RE: How do you use format (SOLVED) - StephenG1CMZ - 06-30-2016 07:12 AM
Thanks, both of those worked. I had tried CAS.format() instead of CAS(format()).
RE: How do you use format - toml_12953 - 06-30-2016 02:08 PM
(06-30-2016 07:12 AM)StephenG1CMZ Wrote:  Thanks, both of those worked. I had tried CAS.format() instead of CAS(format()).
When should I use CAS.command and when should I use CAS(command) ?
Tom L
