(12C) Net Present Value, Net Future Value, Net Utility Stream - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (12C) Net Present Value, Net Future Value, Net Utility Stream (/thread-6666.html) |
(12C) Net Present Value, Net Future Value, Net Utility Stream - Eddie W. Shore - 08-07-2016 07:57 PM Input: Clear the registers/finance registers Press [ g ] (GTO) 00 to get the pointer to line 00. (000 for the HP 12C Platinum editions. Remember, the Platinum editions have up to 400 steps and line numbers are in triple digits) Store -1 in [ n ] (don’t worry, n is incremented in the main loop) Store periodic interest rate in [ i ]. Store 0 in register 0 (0 [STO] [ 0 ]). Register 0 is use for calculating NPV Enter each cash flow one at a time, and press [R/S]. Ready to calculate: Press [ g ] (GTO) 10 (or 010) to get the pointer to line 10. Press [R/S] to get NPV (net present value) Press [R/S] to get NFV (net future value) Press [R/S] to get NUS (net utility stream) Program: Code:
Example: Rate: 15% Cash Flow # Flow 0 -10,000.00 1 2500.00 2 3500.00 3 5000.00 4 5000.00 Input: [ f ] CLEAR FIN, [ f ] CLEAR PRGM -1 [ n ] // do this on each new problem 0 [STO] [ 0 ] // do this on each new problem 15 [ i ] 10000 [CHS] [R/S] 2500 [R/S] 3500 [R/S] 5000 [R/S] 5000 [R/S] Results: [GTO] 10 [R/S]: NPV = 966.76 [R/S]: NFV = 1690.88 [R/S]: NUS = 338.62 Input slowly and carefully. This blog entry is property of Edward Shore, 2016. |
