Special CrossOver for Mac or Linux - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Special CrossOver for Mac or Linux (/thread-6754.html) |
Special CrossOver for Mac or Linux - Sylvain Cote - 08-29-2016 02:37 PM FYI CrossOver 15 for Mac or Linux normally sold for $60 USD is currently available at $20 USD at MacWorld CrossOver is a easy to use wrapper over the open source WINE libraries that allows running Windows applications without a Windows license and without the need to run a virtual machine. It is not perfect but it get the job done most often than none. For sure, if you already have VMware or Parallels and Windows licenses for your VM images then it is useless, but if not, at 20$ it is a great bargain. I run VMWare, Parallels and others VM providers over OSX/Linux/BSD/*nix machines at home when needed, but it is less intrusive, when it works, to run CrossOver. I have bought and installed the latest version (15.2) today and within minutes I was able to run several Virtual IL Tools (ILPer, ILPILBox, etc) from Christoph Gießelink. The only small hiccup was that I had to manually create a soft link to map com4 to the USB-to-Serial interface (in my case /dev/cu.usbserial-AE006AJX) for the ILPer to correctly work. Sylvain Edit: typos RE: Special CrossOver for Mac or Linux - Jurgen Keller - 08-29-2016 06:39 PM I use CrossOver, too. I can confirm that Christoph's IL Tools run fine. I know of other people using this setup, and somebody once sent me a picture of his devices in action, see attachment. RE: Special CrossOver for Mac or Linux - Graan - 09-02-2016 06:48 AM Seems they are working on CrossOver for Android as well. So it means I can run my windows SW on a Android tablet. Interesting.... |
