Question: Why ConnKit stop on Windows - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Question: Why ConnKit stop on Windows (/thread-6766.html) |
Question: Why ConnKit stop on Windows - Marcel - 08-31-2016 11:11 AM Hi! Many times, with all versions, when I connect my Prime to the Connkit and double click on my Prime, the ConnKit crash, and Windows searh for a solution... Do you know why this append? Marcel. RE: Question: Why ConnKit stop on Windows - roadrunner - 08-31-2016 06:18 PM All programs crash while running on a Windows OS. That's part of Window's charm. -road RE: Question: Why ConnKit stop on Windows - Tim Wessman - 09-06-2016 09:08 PM I suspect things will be working much better for you in the current update that just came out. Please give things a try and I suspect you will be much happier with it. RE: Question: Why ConnKit stop on Windows - TravisE - 09-06-2016 11:50 PM I'm not the OP, but I started having the same crashing problem (could not back up the calculator at all), and the update appears to fix it. Thanks, Tim and all! |
