HELP Syntax error with every program added - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HELP Syntax error with every program added (/thread-6785.html) |
HELP Syntax error with every program added - PMTupa - 09-03-2016 08:11 PM Hi everyone, Its been months for me trying to add programs on my hp prime through the connectivity kit... i tried to transfer them from the hp prime emulator and they work on it but once on the actual calculator the programs don't work.. I'm actually just a beginner in the use of calculators and also a french student ![]() (i also red a ton of articles on forums in french and english and nothing helped me so far) thank you and have a good day RE: HELP Syntax error with every program added - cyrille de brébisson - 09-05-2016 05:22 AM Hello, If you could post one of the problematic programs here, we might be able to have a look at it and help you. Cyrille RE: HELP Syntax error with every program added - primer - 09-05-2016 08:22 AM (09-03-2016 08:11 PM)PMTupa Wrote: I'm actually just a beginner in the use of calculators and also a french student Probably the pragma line is missing, ok that's easy to check and to fix. As french you are maybe using coma as decimal separator, like me. What you can do, try to use dot as decimal separator and no digit grouping separator, by the way change integer to hex. There are the most common settings, probably used by people who made programs. Then go back to the program, press "verify" and see if it works. if yes, go to the begining of the program, use [menu] key to "add #pragma" then leave the program, you have fixed the program like a pro ![]() So, come back to your settings to change back to your regional settings and voilà ! good luck. |
