input does not work anymore (10637 ) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: input does not work anymore (10637 ) (/thread-6922.html) |
input does not work anymore (10637 ) - hpfx - 09-25-2016 08:30 PM Hello, I spent lot of time to discover that input cannot be used anymore to handle math expression. Many of my progs does not work anymore here is a simple example I made to show you... In old 8151 firmware this prog did work : Code: EXPORT abc() But in new firmware 10637 it does not work ! => Error. Bad Argument Value surprised this wasn't checked on new firmware release... The problem is that int() does not accept string anymore, is that a bug ? But I found that I still could use single quote like this : int('2*X') But what the hell ?! how can I get single quote out of a PRINT() ? Documentation does not explain it... And WHERE is this f*** list of allowed types ?!!! And is there an "algebraic" type ? I spent hours on that. It is still possible to make program that manipulate math algebraic expression from user input ??? RE: input does not work anymore (10637 ) - roadrunner - 09-25-2016 11:43 PM Try: Code: EXPORT abc() -road RE: input does not work anymore (10637 ) - roadrunner - 09-25-2016 11:51 PM And see the document by Cyrille de Brébisson in post #9 of this thread for a more complete explanation: http://www.hpmuseum.org/forum/thread-6218.html?highlight=kids -road RE: input does not work anymore (10637 ) - roadrunner - 09-25-2016 11:56 PM I meant to type: print(int(eval(a))); in the modification of your code but you should get the idea. -road |
