Purge Corrupted File HP50G - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Purge Corrupted File HP50G (/thread-6983.html) |
Purge Corrupted File HP50G - buffalo - 10-06-2016 06:54 AM Thanks in advance for anyone that can help with this. i somehow have aquired a very nasty corrupt file on my SD card, which i want to be rid of. any action i take with it RCL, VIEW, PURGE, MOVE etc causes the calculator to "hang" for what seems an eternity, it does not respond to reset (ON C) i have to invoke the dreaded paperclip which has cleared memory on many occasions. Does anyone have a possible solution, to my troubles. regards buffalo RE: Purge Corrupted File HP50G - matthiaspaul - 10-06-2016 08:58 AM (10-06-2016 06:54 AM)buffalo Wrote: Thanks in advance for anyone that can help with this.Try it on a PC. The FAT file system implementation in the 49g+/50g firmware is not very robust, it just handles the standard cases, but may easily "hick up" when encountering anything unexpected. On a PC, also run a file system tool like CHKDSK/SCANDISK etc. in order to ensure the integrity of the file system. Greetings, Matthias RE: Purge Corrupted File HP50G - buffalo - 10-06-2016 09:39 AM ok Matthias i will give it a go thanks, will post the results buffalo RE: Purge Corrupted File HP50G - buffalo - 10-06-2016 11:52 AM desktop computer to the rescue problem solved thanks Matthias buffalo |
