This is a code viewer for HP-Prime - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: This is a code viewer for HP-Prime (/thread-6996.html) |
This is a code viewer for HP-Prime - wangchong01 - 10-08-2016 05:32 PM Notice: It seems that the code viewer is only fit for the r10077 or above. But you can have a try using r8151. RE: This is a code viewer for HP-Prime - wangchong01 - 10-09-2016 05:00 AM (10-09-2016 03:04 AM)compsystems Wrote: excellent highlighting code. Try this converter - it will tabulate your code RE: This is a code viewer for HP-Prime - scorpio72 - 07-18-2018 08:23 AM I know this app is here for some time but is it compatible with the last FW 2018 ? On my machine, it starts and asks for a prog to open then nothing happen. Could you please confirm? RE: This is a code viewer for HP-Prime - Tim Wessman - 07-20-2018 02:57 AM (07-18-2018 08:23 AM)scorpio72 Wrote: I know this app is here for some time but is it compatible with the last FW 2018 ? Yes it is, however the author is trying to allocate a gigantic screen image for display which is why it doesn't run on your hardware. The memory limits are being exceeded. Take a look at the line DIMGROP_P(G1,768,14*rowm+5) That is trying to allocate an image that is 768 pixels wide, by 14*512*+5 high *32 bits per pixel .... ~22MB. Previously at 16bits per pixel it is possible it might have worked on a rather empty unit. So that is why the program is not working. In order to work properly on hardware, a routine that either handles a smaller portion of the code at one time, or some other more intelligent methods will be needed. |
