[SOLVED] Bug with INSTRING - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: [SOLVED] Bug with INSTRING (/thread-7105.html) |
[SOLVED] Bug with INSTRING - CH3791 - 10-26-2016 08:37 AM Hello, When I put INSTRING("√7","√") directly into CAS, it returns 1 as expected. However when I put the exact same thing into programs, it returns 0. CAS or non-CAS, it doesn't matter. Code: EXPORT norm_instring_bug(expression) It might have something to do with Prime auto-adding spaces, which I found to have caused some issues during my testing. For example, Prime changes "√" to " √ ". If we now calculate INSTRING("√7"," √ "), it returns 0. RE: Bug with INSTRING - StephenG1CMZ - 10-26-2016 01:02 PM An upper-case INSTRING seems to work. Code:
If an extra space is being inserted, it might be worth trying the equivalent Unicode numeric instead of a string. RE: Bug with INSTRING - Han - 10-26-2016 06:49 PM (10-26-2016 08:37 AM)CH3791 Wrote: Hello, I don't have a calc or a copy of the VC in my reach, but I wonder if there is any difference between running the programs from CAS vs from HOME. My thought process is that in CAS, entering in √7 leaves the quantity in exact form (assuming the necessary settings are in place) whereas in HOME, the quantity is reduced to a decimal approximation. If this simplification happens before that program is even run (as part of the parsing routine), then this may explain why you get 0 as the result all the time. Han RE: Bug with INSTRING - cyrille de brébisson - 10-27-2016 06:13 AM Hello, It might be because your expression is evaluated before the string function is called on it, thus removing the sqrt symbol? Cyrille RE: Bug with INSTRING - toml_12953 - 10-27-2016 06:41 AM (10-26-2016 08:37 AM)CH3791 Wrote: Hello, When I put in the following: Code: EXPORT norm_instring_bug(expression) I get 2 in RPN mode when I enter "√7". I tried with all capitals as well as lowercase keywords. I get 2 every time. Tom L RE: Bug with INSTRING - CH3791 - 10-27-2016 09:36 AM To Stephen: How do I program using unicode numeric? To Han: norm_instring_bug(√7) cas_instring_bug(√7) returns 0 in both Home and CAS. Even if the "exact" setting is ticked in CAS. To Cyrille: At least with the CAS program, it shouldn't have been evaluated right? Because if we have a program like say Code: #cas To Tom: Is your answer of 2 after Prime has automatically added in spaces (so creating a string like this: " √7 ")? Because the answer should be 1 since the √ is in the first position of the string. RE: Bug with INSTRING - StephenG1CMZ - 10-27-2016 01:47 PM To represent the square root symbol as a Unicode numeric use this syntax: Code:
Note: If you look through Shift Chars you can discover other code numbers. But beware that there may be several similar-looking symbols. RE: Bug with INSTRING - StephenG1CMZ - 10-27-2016 03:11 PM (10-27-2016 02:03 PM)moonbeam Wrote:(10-27-2016 01:47 PM)StephenG1CMZ Wrote: To represent the square root symbol as a Unicode numeric use this syntax: My apologies. In my original post, I had used shift/chars and picked up a value that looked like a sqrt or tick on my little screen, and wrote the call syntax. I then used asc(sqrrtsymbol) to find out the actual number and updated my post with the right number - but I was too slow and you read the 1st version. BTW, I am surprised that when using Shift/Chars/More/Maths the symbol for squareroot is not immediately seen - I would have thought it would be one of the first/commonest symbols. But I guess that sequence is Unicode's, not HP Prime's. RE: Bug with INSTRING - Tim Wessman - 10-27-2016 04:35 PM (10-27-2016 03:11 PM)StephenG1CMZ Wrote: BTW, I am surprised that when using Shift/Chars/More/Maths the symbol for squareroot is not immediately seen - I would have thought it would be one of the first/commonest symbols. But I guess that sequence is Unicode's, not HP Prime's. Welcome to unicode! :-) Yes, the character browser is exclusively showing the codepoints in the font. There are plenty of places where characters appear in more then 1 place, don't appear in the same sequence because they already existed somewhere else, and other strange things. Just take a look at the superscript/subscript block... https://en.wikipedia.org/wiki/Unicode_subscripts_and_superscripts#Superscripts_and_subscripts_block RE: Bug with INSTRING - CH3791 - 10-28-2016 07:10 AM Cheers guys, the program works now! RE: [SOLVED] Bug with INSTRING - Jan_D - 11-19-2016 09:11 PM (10-28-2016 07:10 AM)CH3791 Wrote: Cheers guys,Hi CH3791, You have marked the thread as having been solved. Could you please tell us what the solution is because I do not see it anywhere. RE: [SOLVED] Bug with INSTRING - CH3791 - 11-21-2016 10:38 AM Hello Jan If you want to check for square root symbol, you use this code: Code: instring(yourstring,char(226,136,154)) RE: [SOLVED] Bug with INSTRING - Jan_D - 11-21-2016 03:45 PM Hello CH3791, Thank you! |
