Simple HP Prime Program - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Simple HP Prime Program (/thread-7148.html) |
Simple HP Prime Program - cmadon - 11-01-2016 05:43 PM On my previous HP calculators I've had a very simple program for metric conversion. Name: MM << 25.4 / >> Name: IN << 25.4 8 >> I would place a number on the stack and hit the softkey with the function I wanted. I can't figure out how to achieve this on the HP Prime. Can someone please point me in the correct direction. Also, I am using the RPN input format. Thank you. RE: Simple HP Prime Program - toml_12953 - 11-01-2016 05:50 PM (11-01-2016 05:43 PM)cmadon Wrote: On my previous HP calculators I've had a very simple program for metric conversion.create a function: Code: EXPORT MM(x) Then to convert 16 mm to inches, call it like this: 16 <Enter> MM(1) <Enter> RE: Simple HP Prime Program - cmadon - 11-01-2016 06:03 PM Thanks a ton. One additional question, how can I save this to a softkey and have it so I type the number then just press the associated softkey? |
