Comparing Matrices (in CAS Mode?) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Comparing Matrices (in CAS Mode?) (/thread-7153.html) |
Comparing Matrices (in CAS Mode?) - Eddie W. Shore - 11-02-2016 03:48 AM I am trying create a matrix program in CAS mode, isorthogonal, to test whether a matrix is orthogonal: #cas isorthogonal(m):= BEGIN LOCAL s,n,p; s:=SIZE(m); s:=s(1); n:=IDENMAT(s); p:=simplify(TRN(m)*m)); IF n==p THEN RETURN 1; ELSE RETURN 0; END; END; #end Testing [[2,0][0,2]] and [[2*x,0][0,2*x]] I get the error "For: Unable to check test Error: Bad Argument Value" Are we not able to compare matrices in CAS mode? Thanks, Eddie RE: Comparing Matrices (in CAS Mode?) - roadrunner - 11-02-2016 11:33 AM You have an extra ")" in this line: p:=simplify(TRN(m)*m)); I changed it to: p:=simplify(TRN(m)*m); and your program seems to work correctly for me. -road |
