Classic battery door latch 3d model? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Classic battery door latch 3d model? (/thread-7167.html) |
RE: Classic battery door latch 3d model? - mfleming - 09-11-2017 03:18 AM I must have missed that post! Any chance of getting some of the SW bands too? RE: Classic battery door latch 3d model? - Nate Martin - 09-12-2017 05:18 AM (09-10-2017 06:31 PM)mfleming Wrote: What is the overall length of the extended module housing? Looks like there's room enough for an IR diode or, dare I say, GPS module Uploaded a double stack - https://www.shapeways.com/product/87UKD9NE9 (2x height on the back end) and extended - https://www.shapeways.com/product/L99GKC4UW (1.5" longer). The extended could really be any length if the model works and it would be easy to extend the double stack if needed for a project. They are in for a test print now. I have also modeled a standard module housing for the 41 as the base to build these other parts off. I should have the test prints back in about 10 days. Also, I checked the 71 IL door per Sylvain's comment, I had forgotten I had to trim mine to fit correctly so I adjusted the model and uploaded. It should come back with the other test prints above. RE: Classic battery door latch 3d model? - mfleming - 09-12-2017 02:36 PM Very neat! Looking forward to trying both when they've been tested and released. Either one definitely sparks some project ideas... RE: Classic battery door latch 3d model? - Sylvain Cote - 09-13-2017 01:28 AM (09-12-2017 05:18 AM)Nate Martin Wrote: Uploaded a double stack - https://www.shapeways.com/product/87UKD9NE9 (2x height on the back end) and extended - https://www.shapeways.com/product/L99GKC4UW (1.5" longer).Interesting, has a lot of potential, please next time please choose another color than black (or white), I had to rely on the light reflection to correctly see the modules inside. (09-12-2017 05:18 AM)Nate Martin Wrote: Also, I checked the 71 IL door per Sylvain's comment, I had forgotten I had to trim mine to fit correctly so I adjusted the model and uploaded. It should come back with the other test prints above.Great! thanks you. 8-) Sylvain |
