Laplace function a bit limited - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Laplace function a bit limited (/thread-7181.html) |
Laplace function a bit limited - hsauro - 11-05-2016 11:42 PM Just got a new HP prime C series. I tried some Laplace transform derivations and the first two I picked failed, these were: 1/t which I entered as laplace (1/t, t, s) it returned undef and (1-e^{-t})/t entered as laplace ((1-e^(-t))/t, t, s) returned undef. Question is have I entered the equations incorrectly or is the CAS just limited? The 1/t in particular is a standard function to get the laplace transform of, its just 1/s^2. RE: Laplace function a bit limited - Mark Hardman - 11-06-2016 12:40 AM On my first day of Filter Design 214 I learned: ℒ[t] = 1/s^2 https://www.wolframalpha.com/input/?i=laplace(t,t,s) Just saying... Mark Hardman RE: Laplace function a bit limited - hsauro - 11-06-2016 01:37 AM (11-06-2016 12:40 AM)Mark Hardman Wrote: On my first day of Filter Design 214 I learned: Of course I know what the Laplace transform of t is. What I wanted to know was whether the calculator knew, obviously it didn't. As I said, this was surpring for such a basic transform. It suggests to me that the Cas capability at least for Laplace transforms might be limited. I shall need to try some more. RE: Laplace function a bit limited - Mark Hardman - 11-06-2016 01:47 AM (11-06-2016 01:37 AM)hsauro Wrote: Of course I know what the Laplace transform of t is. What I wanted to know was whether the calculator knew, obviously it didn't. As I said, this was surpring for such a basic transform. It suggests to me that the Cas capability at least for Laplace transforms might be limited. I shall need to try some more. No, you said the following: (11-06-2016 01:37 AM)hsauro Wrote: The 1/t in particular is a standard function to get the laplace transform of, its just 1/s^2. Which is demonstratively false. The CAS is telling you that there is no standard form for: ℒ[1/t] WolframAlpha agrees. https://www.wolframalpha.com/input/?i=laplace(1%2Ft,t,s) "(no result found in terms of standard mathematical functions)" Mark Hardman RE: Laplace function a bit limited - hsauro - 11-06-2016 01:58 AM (11-06-2016 01:47 AM)Mark Hardman Wrote:(11-06-2016 01:37 AM)hsauro Wrote: Of course I know what the Laplace transform of t is. What I wanted to know was whether the calculator knew, obviously it didn't. As I said, this was surpring for such a basic transform. It suggests to me that the Cas capability at least for Laplace transforms might be limited. I shall need to try some more. My bad I apologize, don't know why I typed in 1/t ! Prime certainly can do t. Anyone one reading this thread, it's a false alarm, sorry for the confusion. RE: Laplace function a bit limited - hsauro - 11-06-2016 02:06 AM (11-06-2016 01:58 AM)hsauro Wrote: [quote='Mark Hardman' pid='63693' dateline='1478396852'] If any one has the power to delete threads this is one that should probably be deleted in case it inadvertently mismlead ssomeone, since the original premise is incorrect. RE: Laplace function a bit limited - CH3791 - 11-06-2016 02:27 AM You can delete threads yourself. Just click edit>full edit and on the top there is an option to delete. |
