Different ROM versions HP80? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Different ROM versions HP80? (/thread-7224.html) |
Different ROM versions HP80? - Harald - 11-12-2016 01:59 PM When playing with Tonys emulator I found it behaves differently than my real HP80. I get slighty different results from some calculations, but the most obvious and very easy to reproduce thing is: Turn on the calculator, press divide, which of course results in an error. Pressing Enter now puts a 10 in the x register. My real HP80 has 9.999999999 e99 in the X register. Cheers, Harald RE: Different ROM versions HP80? - Etienne Victoria - 11-12-2016 04:52 PM Ok, Here : 1247A 05142 and 1247A 46954 both put a 10 in the x register. I'll try to get a hand on my Singapores and report. Cheers Etienne RE: Different ROM versions HP80? - Harald - 11-12-2016 11:14 PM (11-12-2016 04:52 PM)Etienne Victoria Wrote: Ok, Hi Etienne! Your Calculator has arrived today, thanks a lot! It is without battery terminals and I need to work out why the decimal points are not working. Also I will replace one LED cluster due to a bad Segment. But I have all the parts to do this, so please keep your other calculators. You will need one to put the PCB in once I send it to you. However I tested this one and it behaves exactly like the one I already have. Both are the newer version with the 2 ROM chips. So I guess the version with the hybrid is not only physically different, but also the contents is different Cheers, Harald RE: Different ROM versions HP80? - Etienne Victoria - 11-13-2016 06:19 PM Hi Harald, Glad you got the 80 and can actually make good use of it :-) Yes, the ROM content must be different ; maybe they had the opportunity to update it when changing design and production site. From the samples I have, the 1247A are on the left and the 1704S on the right of the pictures. And the board underwent a couple of changes: 1247A: 1704S: Cheers Etienne |
