Flashing HP20B - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Flashing HP20B (/thread-7226.html) |
Flashing HP20B - Matthias DD. - 11-12-2016 05:07 PM Hi, Would somebody like to help me flashing an HP20B to WP34s. I live in Germany, but sending it to USA would not be that expensive. Thank you. Und falls jemand in Deutschland helfen könnte, wäre natürlich auch prima. Ich habe es mit dem Arduino einfach nicht geschafft. Gruß Matthias RE: Flashing HP20B - Harald - 11-12-2016 10:55 PM (11-12-2016 05:07 PM)Matthias DD. Wrote: Hi, Hi Matthias, PM me and I'll mail you my address. I can flash the calculator for you. Cheers, Harald RE: Flashing HP20B - Matthias DD. - 11-13-2016 06:24 AM Thank you Harald, Somebody from Germany would flash it for me. But have just a problem with the display. See pic. What do you mean, is it serious? Bye Matthias [attachment=4143] and what about 10bII+? - RE: Flashing HP20B - Csaba Tizedes - 11-13-2016 12:52 PM Little OFF, but: it is possible to install stopwatch crystal + firmware upgrade on 10BII+? For example with keystrokes [LS]+[RS] change to stopwatch mode and back and the split times are stored into registers from R00 to R19 as FILO stack structure. Any comment on possibility?! Thanks! Csaba RE: Flashing HP20B - Harald - 11-13-2016 01:10 PM (11-13-2016 06:24 AM)Matthias DD. Wrote: But have just a problem with the display. See pic. Hi Matthias, That looks strange. I am not sure what happened there. It is best to try and flash the calculator again and see if it works ok. RE: Flashing HP20B - damaltor - 11-14-2016 10:21 AM I could help from germany if still needed. The display is probably leaking a little, which might be due to age (uncommon) or physical stress - it might go away in a while, or it might also stay. in some cases, the leak will get bigger. i would not bother as long as it does not disturb you. if it really is a leak (or "bleed"), it cannot be repaired. |
