[Request] HPconnKit HP-Prime (Program Editor) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: [Request] HPconnKit HP-Prime (Program Editor) (/thread-7259.html) |
[Request] HPconnKit HP-Prime (Program Editor) - compsystems - 11-18-2016 07:26 PM Hello To facilitate the development of applications and programs I propose 1: Allow resizing of the edit source. 2: A menu to format or tabulate the text, it is very complicated to do it manually 3: a toolbar with menus of the programming templates 4: collapse and expansion of code blocks 5: show file size 6: Generate popup warning boxes, when the file plus from 31 chars (sent and store) 7: menus to sort files by name, by date 8: menu to search for and replace words 9: show multiple files by tabs RE: [Request] HPconnKit HP-Prime - toml_12953 - 11-18-2016 08:17 PM (11-18-2016 07:26 PM)compsystems Wrote: Hello Yes! I don't understand # 6, but totally agree with the rest! Tom L and allow printing! Always printing! RE: [Request] HPconnKit HP-Prime - Han - 11-18-2016 08:27 PM (11-18-2016 08:17 PM)toml_12953 Wrote:(11-18-2016 07:26 PM)compsystems Wrote: Hello #6 refers to the limit on the length of file names (or was it function names?) RE: [Request] HPconnKit HP-Prime - toml_12953 - 11-18-2016 08:31 PM (11-18-2016 08:27 PM)Han Wrote:(11-18-2016 08:17 PM)toml_12953 Wrote: Yes! I don't understand # 6, but totally agree with the rest! Oh! Then I totally support #6 too! Tom L and allow printing. Always printing! RE: [Request] HPconnKit HP-Prime - compsystems - 11-19-2016 04:41 AM (11-18-2016 08:27 PM)Han Wrote: #6 refers to the limit on the length of file names (or was it function names?) Files with more than 31 characters, can not be appended to the program directory (HPconnKit), and the program does not say that it occurs Function name with more than 31 characters compiler, cut the name, but there is problem if two functions have the same prefix RE: [Request] HPconnKit HP-Prime - primer - 11-19-2016 10:46 AM and #10 : functions browser. RE: [Request] HPconnKit HP-Prime - compsystems - 11-20-2016 09:02 PM I just missed an afternoon of work I accidentally deleted a program. Suggestion: 11: When a program is deleted, send it to the recycle folder RE: [Request] HPconnKit HP-Prime - DrD - 11-20-2016 11:03 PM Go on back to work, you can just restore your deleted program from the backup you made. RE: - compsystems - 11-20-2016 11:10 PM I did not make a backup =(, another request ... every x minutes should ask if you want to make a backup, How it does, microsoft word. RE: [Request] HPconnKit HP-Prime (Program Editor) - chromos - 11-21-2016 03:24 AM I have request too: dear compsystems, is there anything in hp-prime you like? :-) RE: [Request] HPconnKit HP-Prime (Program Editor) - compsystems - 11-21-2016 03:38 AM (11-21-2016 03:24 AM)chromos Wrote: I have request too: dear compsystems, is there anything in hp-prime you like? :-) Many things I like about hp-prime, prgm Language, CAS, simulator, ..., has evolved quickly, with user suggestions, ideas and comparisons with other products we can make it the best calculator on the world. =] RE: [Request] HPconnKit HP-Prime (Program Editor) - DrD - 11-21-2016 11:31 AM (11-20-2016 11:10 PM)compsystems Wrote: I did not make a backup =(, another request ... every 15 minutes should ask if you want to make a backup Who would have thought that -you- wouldn't have thought to make a backup of an important file? Oh well, hp happens. You could still have stayed at work because, luckily, you can copy your program from the notepad ++ file, that you use. Your lost program is a very important program, and way more important than your employment. Good thing you have an hp prime to match your priorities! If all else fails, you will still be able to recreate your lost program ... from your own knowledge, skill, and abilities. Based on all of your previous advice and guidance to the hp team, your aptitude must surely be commensurate. Miss a little more work time, the demands of the workplace will understand, and I will certainly understand if your programming demands take you away from your forum contributions for awhile, (if need be). Good luck! |
