battery drains too fast - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: battery drains too fast (/thread-7365.html) |
battery drains too fast - mrivev - 12-04-2016 10:59 PM Hi I have a problem with the battery of my HP Prime, a charge usually used to last about 2 weeks sometimes even more however suddenly it just last less than a day. I read other posts saying its a firmware issue so I downgrade from 10637 to 8151 and to 5547 without any positive result. Does any body had the same problem?, is there any solution? If there is a battery issue I found out that a Galaxy S3 battery could replace the original one is it true does any body try it before? (https://www.omnimaga.org/news/put-a-samsung-galaxy-s3-battery-in-your-hp-prime/) Thanks in advance. RE: battery drains too fast - akmon - 12-05-2016 09:50 AM Samsung S3 battery works perfectly. You can try it. RE: battery drains too fast - cyrille de brébisson - 12-05-2016 10:31 AM Hello, This is strange as the battery life should not have changed. You are correct, the galaxy S3 battery will work. Cyrille |
