HP Restoration - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP Restoration (/thread-7403.html) |
HP Restoration - coerrace - 12-11-2016 01:35 AM I see this link: http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv019.cgi?read=153539 Someone knows where to find that book or any technique of restoration? I have an HP 16C with the HP logo a little deteriorated. Thank you RE: HP Restoration - Geoff Quickfall - 12-11-2016 06:37 AM Oh no! Another book request :-) Very soon, very soon. Show me a pic of your logo. There are sometimes spares and I think someone did one at Shapeways for the 15C. Is yours missing or just has the plating tremoved? Geoff RE: HP Restoration - Massimo Gnerucci - 12-11-2016 08:44 AM (12-11-2016 06:37 AM)Geoff Quickfall Wrote: Oh no! Another book request :-) Sigh Another sad Christmas without THE Book... :'( RE: HP Restoration - Geoff Quickfall - 12-11-2016 09:17 AM And so it begins! RE: HP Restoration - PANAMATIK - 12-11-2016 10:19 AM (12-11-2016 09:17 AM)Geoff Quickfall Wrote: And so it begins! It never ends I'm planning two new replacement ideas for next year. Keep two chapters free! Bernhard RE: HP Restoration - aurelio - 12-11-2016 11:29 AM (12-11-2016 08:44 AM)Massimo Gnerucci Wrote:I will charge my great-grandchildren to ask when the book is ready(12-11-2016 06:37 AM)Geoff Quickfall Wrote: Oh no! Another book request :-) RE: HP Restoration - Massimo Gnerucci - 12-11-2016 12:27 PM (12-11-2016 09:17 AM)Geoff Quickfall Wrote: And so it begins! AHAHAH! Quick, or the one needing restoration will be me! RE: HP Restoration - aurelio - 12-11-2016 12:55 PM (12-11-2016 12:27 PM)Massimo Gnerucci Wrote:I've performed yesterday on myself a masterclear but does not work(12-11-2016 09:17 AM)Geoff Quickfall Wrote: And so it begins! +1 RE: HP Restoration - coerrace - 12-11-2016 02:49 PM Ohhh the book not finished ok when you finish I want a copy. Here are pictures of the HP16C logo I want to restore: RE: HP Restoration - aurelio - 12-11-2016 04:03 PM (12-11-2016 02:49 PM)coerrace Wrote: Ohhh the book not finished ok when you finish I want a copy. cannot see the images, maybe something wrong with the link RE: HP Restoration - coerrace - 12-11-2016 04:08 PM This are the links in html instead: https://postimg.org/image/5656i8hxn https://postimg.org/image/q4bcgbhsb If links not work here without using the editor: https://postimg.org/image/5656i8hxn https://postimg.org/image/q4bcgbhsb RE: HP Restoration - Geoff Quickfall - 12-12-2016 06:04 PM Hello, The badge is easy to remove and is of two types. The early badges were stamped metal, polished and painted on the recesses. They are easy to restore. Yours is problematic and have been a source of frustration for many, leading one member to make metal ones at Shapeways I think, but for the 15c: 1). http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv019.cgi?read=172067 2). http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv020.cgi?read=200553 Back to yours, they are vacuum plated chrome on plastic, similar to internal car fixtures. They may be painted but the paint wears and is not robust. There is this alternative; I actually removed them, then polished the plastic to remove the remaining chrome plate and painted the recess with black paint creating a negative image: 3). http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv018.cgi?read=139782 To remove one you need to cover the lcd display with a cloth and apply heat to the badge (a hair dryer will suffice). When the badge is hot to the touch the contact cement will release allowing you you to pick the badge out. I then give the face of the badge a polish using plastic polish (motorcycle windshield polish) removing the remaining vacuum plated chrome. Then repaint the originally chromed area with silver, for plastic model, paint. Or reproduce the negative version I created which will never wear (URL #3 above). Sorry, couldn't be much more help but I will post this also and see if someone has created a metal bagpdge at Shapeways. Geoff RE: HP Restoration - Didier Lachieze - 12-12-2016 07:56 PM You may also try a silver leafing pen such as this one. RE: HP Restoration - coerrace - 12-12-2016 08:13 PM (12-12-2016 07:56 PM)Didier Lachieze Wrote: You may also try a silver leafing pen such as this one. But with that technique of the pen could be wear out easily or not? RE: HP Restoration - Didier Lachieze - 12-12-2016 08:33 PM (12-12-2016 08:13 PM)coerrace Wrote:I don't know, I don't have tried it on a Voyager. On my HP 55 it has not worn out.(12-12-2016 07:56 PM)Didier Lachieze Wrote: You may also try a silver leafing pen such as this one. RE: HP Restoration - Vtile - 12-12-2016 09:54 PM Looking that link on the first post to some old thread... It did jump to me, have anyone tried a heated (by external flame ie. with spirit lamp) flatnose pliers to deform those heatformed attachment points that are used many, if not all the older hp-calcs.. RE: HP Restoration - Geoff Quickfall - 12-12-2016 09:59 PM If you are talking about the heatstakes then yes, remelting is possible if enough of the heat stake was left. I use a solder iron to mushroom the remaining stake and add glue. Others have used TINY screws! Geoff Silver leaf pen and etc. do wear on surfaces exposed to wear. The badge when slipped into the calculator sleeve or when sitting upside down on the desk will wear. It is proud of the bezel surface. RE: HP Restoration - anetzer - 12-13-2016 05:38 AM Hello everybody, This thread has turned interesting in so many different ways... I guess it to be rather pointless to ask Geoff for more specific data concerning the actual publishing. May he rest assured that many here do wait very eagerly and are weighing each and any words he is offering on the state of his project with breathless anticipation... Two questions however: I did not find any voyager logo on Shapeways. Did the offer vanish? More generally: i do know that the spires of this august forum tend to be rather sceptical of the practicability of 3D printing and do admit that printing materials and quality might still be imadequate. However: When might we see some of the oft-worn parts like e.g. the lower half of an HP-41 shell being offered as sturdy and unobtrusive 3D facsimiles? Thank you for opinions, a. RE: HP Restoration - Geoff Quickfall - 12-13-2016 06:37 AM Publish date... There are a few 3D printing offers out there for HO parts: Classic battery hatch clips, HP 41 battery hatch covers, HP71B module covers and fram card reader covers. Hp34C series battery hatch eps. The voyager badges don't look 3D printed, but cast. I do remember someone thinking about them but cannot find the link. I just designed some buttons out of metalized plastic (aluminide) for my Seiko QC-951. I see thay sell for $18 dollars a copy, I may get aluminum printed now, if the plastic design doesn't need tweaking, for my clock. Geoff RE: HP Restoration - Massimo Gnerucci - 12-13-2016 06:57 AM (12-13-2016 06:37 AM)Geoff Quickfall Wrote: The voyager badges don't look 3D printed, but cast. I do remember someone thinking about them but cannot find the link. Dallas Osborne and his HP11C badge replacement casted out of silver. |
