[SOLVED] Newest fw INPUT syntax? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: [SOLVED] Newest fw INPUT syntax? (/thread-7442.html) |
[SOLVED] Newest fw INPUT syntax? - chromos - 12-19-2016 12:18 AM 1) Please, do you anybody know which is new syntax for INPUT command? I need store expressions, something like A+B or G-K/L etc. It worked in previous fw, but I am unable understand current syntax - I tried "everything", but everytime I get orange exclamation mark and programm is still on INPUT screen. 2) Is there alternative to lname command in Home? Thank you very much. RE: Newest fw INPUT syntax? - Han - 12-19-2016 02:24 AM (12-19-2016 12:18 AM)chromos Wrote: 1) Please, do you anybody know which is new syntax for INPUT command? I need store expressions, something like A+B or G-K/L etc. It worked in previous fw, but I am unable understand current syntax - I tried "everything", but everytime I get orange exclamation mark and programm is still on INPUT screen. It helps to share a snippet of your code so we can help debug. RE: Newest fw INPUT syntax? - chromos - 12-19-2016 02:58 AM OK, this worked until fw update to latest release: PHP Code: INPUT(Temp,[2],"Expression","Variables must be in UPPERCASE! (e.g. A+B-4)"); I tried many variations of [2] - with different parentheses, even without them, at different places - with no success. That line code is line # 293 from Geo Coords Solver: http://www.hpmuseum.org/forum/thread-5361-post-48133.html#pid48133 RE: Newest fw INPUT syntax? - DrD - 12-19-2016 11:18 AM Did you create local variable Temp, first? Would this adaptation be of any use to you? Code:
-Dale- RE: Newest fw INPUT syntax? - Tim Wessman - 12-19-2016 04:56 PM (12-19-2016 12:18 AM)chromos Wrote: 1) Please, do you anybody know which is new syntax for INPUT command? I need store expressions, something like A+B or G-K/L etc. It worked in previous fw, but I am unable understand current syntax - I tried "everything", but everytime I get orange exclamation mark and programm is still on INPUT screen. It seems to work fine for me here (provided Temp has been defined as pointed out). Quote:2) Is there alternative to lname command in Home? LNAME is also a home command. Takes an expression 'X^2+Y' for example, and returns { X, Y }. Does that do what you want? If none of the answers given seem to help you, please post some snippets so we can see and help more. RE: Newest fw INPUT syntax? - chromos - 12-19-2016 06:00 PM Your example works, thank you very much, Dale. RE: Newest fw INPUT syntax? - chromos - 12-19-2016 06:04 PM Thank you Tim for your advice about LNAME command in Home. I was almost sure I saw it somewhere in the past, but I didn't remember single quotes. Both my questions are solved now. |
