Step-by-step programs in CAS - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Step-by-step programs in CAS (/thread-7549.html) |
Step-by-step programs in CAS - compsystems - 01-10-2017 05:43 PM Hello, I'm trying the following code (Step-by-step), but I see something strange in the output, please run the following program PHP Code: #cas testInequality(); [ expr0: (--4+4)>(x^2+x--4-2) left: --4+4 right: x^2+x--4-2 ] This is expected [0>(x^2+x-6), 0, x^2+x-6] RE: Step-by-step programs in CAS - Han - 01-10-2017 05:56 PM (01-10-2017 05:43 PM)compsystems Wrote: Hello, I'm trying the following code (Step-by-step), but I see something strange in the output, please run the following program When I copied your code, the "-" symbol in front of the 4 (in "step 4") was translated to two dashes: --4. Perhaps your editor is not using the correct symbol for subtraction. RE: Step-by-step programs in CAS - compsystems - 01-10-2017 06:57 PM Thanks Han, (Updated above code), The problem was that when porting a code from ti68k, which uses the character #173 (-) as a change of sign, That is not the change of sign in the hp-prime PHP Code: // ti68k |
