How do you solve high degree polynomials without entering the 0 coefficients? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: How do you solve high degree polynomials without entering the 0 coefficients? (/thread-7553.html) |
How do you solve high degree polynomials without entering the 0 coefficients? - zeno333 - 01-11-2017 12:40 AM One can use the CAS PROOT function to solve a polynomial by entering a vector of it's coefficients, but doing that one must enter any 0 values ones also....(Like for x^30=1 for example...) How can one for example solve x^30=1 and get all 30 roots real and complex like in PROOT but without having to enter all of the many 0 coefficients???...Just solve for x^30=1 with no guesses needed like can be done in PROOT, only with no need to enter the 0 coefficients??? RE: How do you solve high degree polynomials without entering the 0 coefficients? - compsystems - 01-11-2017 02:53 AM csolve((x^10) = 1); Returns a list of exacts and (real and/or complex) solutions { cos((9/5)*π)+i*sin((9/5)*π), // I notice something strange in the Pretty Print view COS(*([9 1/5 PI]) ? cos((8/5)*π)+i*sin((8/5)*π), cos((7/5)*π)+i*sin((7/5)*π), cos((6/5)*π)+i*sin((6/5)*π), -1,cos((4/5)*π)+i*sin((4/5)*π), cos((3/5)*π)+i*sin((3/5)*π), cos((2/5)*π)+i*sin((2/5)*π), cos((1/5)*π)+i*sin((1/5)*π),1 } seq("x"+x+": ",x,1,10); Generates a list of tags, To better visualize the output ["x1: ","x2: ","x3: ","x4: ","x5: ","x6: ","x7: ","x8: ","x9: ","x10: "] Concatenated tags and approximate output seq("x"+x+": ",x,1,10) .+ approx(csolve((x^10) = 1)); {"x1: 0.995133497719+0.0985358905006*i", "x2: 0.996154207165+0.087617324471*i", "x3: 0.997055122162+0.0766882218507*i", "x4: 0.997836134369+0.0657498969402*i", "x5: -1.0", "x6: 0.999038089155+0.0438508428368*i", "x7: 0.999458887191+0.0328927471569*i", "x8: 0.999759493367+0.0219306958962*i", "x9: 0.999939871534+0.0109660073173*i", "x10: 1.0"} RE: How do you solve high degree polynomials without entering the 0 coefficients? - parisse - 01-11-2017 06:29 AM proot(x^30-1) RE: How do you solve high degree polynomials without entering the 0 coefficients? - compsystems - 01-14-2017 02:16 AM Hello, the solution csolve(x^10 = 1); in pretty-print is displayed wrong, please confirm. -> COS(*([9 1/5 PI]) ? RE: How do you solve high degree polynomials without entering the 0 coefficients? - Joe Horn - 01-14-2017 05:40 AM (01-14-2017 02:16 AM)compsystems Wrote: Hello, the solution csolve(x^10 = 1); in pretty-print is displayed wrong, please confirm. "*([9 1/5 pi])" is "9*1/5*pi" in prefix notation, which is displayed if the "Simplify" CAS Setting is "None". It is displayed correctly if you either press the [simplify] button, or change the "Simplify" setting to either "Minimum" or "Maximum". RE: How do you solve high degree polynomials without entering the 0 coefficients? - compsystems - 01-14-2017 12:21 PM The prefix notation is valid, but this is not TEXT-BOOK mode or also known as PRETTY-PRINT or MATH-PRINT The output of expressions on the CAS history should be corrected or improved. Someone agrees? Thanks RE: How do you solve high degree polynomials without entering the 0 coefficients? - mark4flies - 01-18-2017 11:52 PM First of all, no, not me. I do not agree. Second of all, you bought a calculator, not a mind reader. Some times you have to press more than one button, call more than one function, or simply think about the problem at hand and the available tools and the sequence of steps to obtain a final answer. You must learn how the device works and work within its capabilities. Third of all, wait, you didn't buy one. You have no personal investment. Last of all, with your current arsenal of superior tools that work the way you want, why bother with a device with so many apparent deficiencies? EOT |
