Favorite HP41 development environment - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Favorite HP41 development environment (/thread-7665.html) |
Favorite HP41 development environment - dingebre - 01-26-2017 09:55 PM Won't bore with my "story", just glad to have rediscovered my HP41 and the amazing people here and elsewhere who have helped fulfill at least part of my midlife crisis First, I have scoured this and other sites and have discovered a wealth of resources (see below). I'm just wondering which pieces others use and what works best. I would like to know what tools are the most commonly/effectively used to do the following: 1. Edit FOCAL and/or MCODE code on a PC. 2. Assemble/Compile to a ".BIN" 3. Create a ".ROM" and/or ".MOD" to then burn into an MLDL, CLonix/NOV, or other hardware (I have several of Diego's CLonix-D and NOV-64 modules, amazing). I use Windows10, but have installed DOSBOX successfully. I think I've got a decent handle on doing the development on the 41 side, building the image in a Q-ROM device and getting that image out of the NOV-64 RAM to the PC for storage, sharing, or programming back into the ROM space of a Clonix-D or NOV-64 or other device, but the idea of being able to edit with a QWERTY keyboard, add comments, etc. is just more appealing. So, what are your preferred development tools and development path? Here are some of the tools I've found and examined. Please tell me if I've missed something. HP SDSII SDK41R6 Excel Spreadsheet Programming Environment HP41UC HP41UCC HP41 Assistant Others that I'm sure I forgot or missed Other various bits to help facilitate: ILPer and EMU41 with PIL Box HP41E Various HP utilities DOSBOX Clonix-D/NOV-64/USB-41 HP9114B disc drive HP-IL to RS232, IL to HPIB, and IL Converter Thanks David RE: Favorite HP41 development environment - Monte Dalrymple - 01-28-2017 05:11 PM I use SDK41R6 exclusively, but then I only need .ROM files. My only quibble is that it doesn't seem know all of the mainframe entry points. It also doesn't do .MOD files. RE: Favorite HP41 development environment - dingebre - 01-28-2017 05:25 PM (01-28-2017 05:11 PM)Monte Dalrymple Wrote: I use SDK41R6 exclusively, but then I only need .ROM files. My only quibble is that it doesn't seem know all of the mainframe entry points. It also doesn't do .MOD files. Thanks Monte. David RE: Favorite HP41 development environment - Sylvain Cote - 01-28-2017 07:49 PM Hello David, Meindert Kuiprs MLDL2000 Windows application is a great tool to translate ROM to/from MOD format and to read/write MOD header information. You do need the MLDL2000 peripheral to use the software. Sylvain RE: Favorite HP41 development environment - MeindertKuipers - 01-30-2017 06:11 PM (01-28-2017 07:49 PM)Sylvain Cote Wrote: Hello David, Almost correct, the hardware itself is NOT needed, although the USB driver may need to be installed RE: Favorite HP41 development environment - dingebre - 01-30-2017 06:33 PM (01-30-2017 06:11 PM)MeindertKuipers Wrote:(01-28-2017 07:49 PM)Sylvain Cote Wrote: Hello David, Thank you. I'll have a look at the software. David |
