First HP-97 simulator for iPad - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: First HP-97 simulator for iPad (/thread-769.html) |
First HP-97 simulator for iPad - Willy R. Kunz - 02-25-2014 03:25 PM I'm pleased to announce RPN-97 Pro, currently the only HP-97 simulator available on the iTunes Store. It's fully compatible with the HP-67 simulator RPN-67 Pro. Virtual program and data cards may be easily exchanged between the two calculators. Anecdotal aside: Apple initially rejected RPN-97 Pro because it "downloaded and executed code". Only after I explained to them that a HP-97 program is basically a sequence of automated calculator keyboard punches did they accept it. For details, check out my homepage. Screenshots: [attachment=333] [attachment=334] RE: First HP-97 simulator for iPad - Namir - 02-26-2014 03:33 PM I bought the HP-97 Pro software. My first oibservation is that I cannot readily use the HP-67 Pro "cards" that I have already downloaded. Can you allow the two apps to share magnetic cards in an update?? The HP-97 layout is smaller than the full-screen HP-67 which I LOOOOOOVE!!! Cheers, Namir RE: First HP-97 simulator for iPad - Willy R. Kunz - 02-27-2014 11:13 AM (02-26-2014 03:33 PM)Namir Wrote: I bought the HP-97 Pro software. My first oibservation is that I cannot readily use the HP-67 Pro "cards" that I have already downloaded. Can you allow the two apps to share magnetic cards in an update?? Full card compatibility between RPN-67 Pro and RPN-97 Pro is a main feature of these apps. I use it all the time. Please use the Contact link on my homepage so we can figure out via e-mail why it doesn't work in your case. Cheers, Willy RE: First HP-97 simulator for iPad - bshoring - 02-28-2014 08:32 AM Congratulations Willy, on a beautiful calculator! It may be a while before I get to try it as my 1st Gen iPad uses iOS 5.x. However I checked it out in the App Store and it looks impressive! Regards, Bob RE: First HP-97 simulator for iPad - Namir - 02-28-2014 12:46 PM Willy, Does the transfer of magnetic card programs between the 67 and 97 occur via iTunes software (using drag and drop?)? I have not tried using iTunes yet. I do have the iPad 3 and the iPad Air with both the 67 Pro and 97 Pro installed on both. Namir RE: First HP-97 simulator for iPad - Willy R. Kunz - 03-01-2014 06:04 PM (02-28-2014 12:46 PM)Namir Wrote: Willy, Namir, Exactly. That's the way to transfer cards between different installations of RPN-67 Pro and RPN-97 Pro, and also how to import cards downloaded from my site. As with real HP-67/97 calculators, keycode translation occurs automatically. Details are described here: http://www.cuveesoft.ch/rpn67/p05.html Willy RE: First HP-97 simulator for iPad - Namir - 03-02-2014 12:45 PM Thanks Willy. I think my problem should be solved. I am away from home, visiting my son, and I have mailed my iPad to his address. I should be getting it in a day or two and will use iTunes to transfer the HP-67 Pro programs to the HP-97 Pro. Namir |
