CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - Printable Version
+--- Thread: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? (/thread-7810.html)
CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - jebem - 02-22-2017 11:33 PM
"Factoring made easy" by Casio in 1986!
Was this CASIO fx-5500 the first calculator in the market able to do symbolic calculus (formula manipulation) although in a very limited format, otherwise known as C.A.S. these days?
This machine belongs to another local collector that kindly allowed me to have for some time for testing.
[Image: Casio_fx-5500_002.jpg]
This is a handy little machine, almost of the same size and form as the HP Voyager series, although featuring totally different capabilities and operation philosophy.
[Image: Casio_fx-5500_000.jpg]
Main features, based on the user manual:
  • 24 digit LCD with 5x7 dot matrix alphanumeric capability.
  • Analog contrast adjustment.
  • Constant Memory.
  • Power supply: 2xCR2032
  • True algebraic logic operation. Replay for easy editing
  • Display: 10 digits mantissa and 2 digits exponent.
  • Internal: 12 digits mantissa and 2 digits exponent.
  • Each result is rounded to 10 digits for display
  • Stack sizes:
    - Manual operations: Numeric 8 levels, command 20 levels.
    - Formula manipulation: Numeric 15 levels, command 20 levels.
  • Input buffer size for each entry: 79 steps storage area for numbers and commands
  • Memories:
    - 3 x Formula memories (I, II, III). Each up to 79 steps.
    - 12 x Register memories (A to L)
  • 34 functions
  • Symbolic calculus (Formula manipulation):
    - Expansion
    - Factoring
    - Simplify
  • Solver (one unknown quadratic and linear, three unknown linear)
Forensics test: arcsin (arccos (arctan (tan (cos (sin (9) ) ) ) ) )
Result: 9.000007164 the same as for the Casio fx-730P among others.
Doing (9-Ans) *1000000 to find additional internal digits gives just 7.164.
[Image: Casio_fx-5500_003.jpg] [Image: Casio_fx-5500_004.jpg]
Using some expressions from the user manual examples to test the symbolic manipulation capability.
Well, it is not a powerful manipulation and we can't even consider it a full C.A.S. system, but in 1986 it was something rare, if not unique, to see on a pocket calculator.
Simplify 5X^2 + 7X - 6 - 3X^2 + 2X + 9
Took about 2 seconds to find this result: 2X^2 +9X + 3
[Image: Casio_fx-5500_009.jpg] [Image: Casio_fx-5500_010.jpg]
Just for fun, tried to Expand (X + 3)^5
It took about 8 seconds to find this result: X^5 + 15X^4 + 90X^3 + 270X^2 + 405X + 243
[Image: Casio_fx-5500_011.jpg] [Image: Casio_fx-5500_012.jpg] [Image: Casio_fx-5500_013.jpg]
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - jebem - 02-22-2017 11:52 PM
Tear down.
Back cover.
Power supply: 6VDC, 0.01W
[Image: Casio_fx-5500_008.jpg]
Serial number suggests a date of 1986, February (6B).
Removing the aluminum back cover by undoing the two screws reveals the metallic sliding battery cover.
[Image: Casio_fx-5500_020.jpg]
Removing the inner plastic frame by undoing eight self taping screws. Lift it at the battery side first, then use a plastic pry tool to unlatch the remaining sides leaving the display side to the end.
Note the grounding/shielding spring at the lower left side, interconnecting the front face plate and back cover to the circuit common ground.
[Image: Casio_fx-5500_021.jpg]
The PCA is free to be removed. Lift it on the battery side first, then gently pull the display assembly to remove it from the front cover bed.
[Image: Casio_fx-5500_022.jpg] [Image: Casio_fx-5500_023.jpg]
Unfolding the display flat cable to uncover the main PCA components:
  • Hitachi HD61747B32 6B 23 HM47B-32 Processor (1986)
  • Hitachi HD61747B33 5M 13 HM47B-33 Processor (1985)
  • NEC D1004G (uPD1004G) NM390 6527KK 4K 4-bit words or 2KByte SRAM memory (*)
  • Toshiba 4071BF 86 10HB CMOS Quad 2-input OR gates
(*) Can't find information on the NEC uPD1004G IC.
However, Kyoro's Room Blog documents the Casio PB-770 internals and we know that it uses four of these chips for a total of 8KByte of SRAM memory.
The Hitachi HD61747 processors are used in several Casio models, only changing the firmware code. For example:
  • fx-5200P:
    Hitachi HD61747B16
    Hitachi HD61914C 1KByte static RAM
  • fx-4000P:
    - Hitachi HD61747B38
    - HD61914 8kbit static RAM
  • FC-200:
    - HD61747B55
    - HD61914 1KByte static RAM.
  • PB-120:
    - HD61747B57 9L 13
  • PB-500:
    - HD61747B05 5K 13
    - HD61747B06 5H 13
  • PB-770:
    - HD61747B13 5C 13
    - HD61747B14 5C 13
[Image: Casio_fx-5500_024.jpg] [Image: Casio_fx-5500_025.jpg]
Membrane keyboard using rubber keys and painted labels.
Not the best solution but the painting was good and it never fails to register a key.
[Image: Casio_fx-5500_026.jpg] [Image: Casio_fx-5500_027.jpg] [Image: Casio_fx-5500_028.jpg]
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - Leonid - 02-23-2017 06:06 AM
Font exponent changes only for "2"?
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - damaltor - 02-23-2017 07:18 AM
(02-23-2017 06:06 AM)Leonid Wrote:  Font exponent changes only for "2"?
No, at least up to 5 as seen here:
https://3.bp.blogspot.com/-FUqllsi3JUQ/WK4CmVysKSI/AAAAAAAAFec/XdvnJgepq8EmRnWwO7k-q3K1pJXn74JNACLcB/s1600/Casio_fx-5500_012.jpg
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - jebem - 02-23-2017 11:03 AM
Yap, there is no limitations concerning its ability to present exponents in superscript mode, up to the supported limits, of course.
The fx-5500 User Manual is available at the LeDuDu site, so you may have a more detailed look.
Here is another example:
Simplify 2X^6 x 3X^7 x 5X^89 + 3Y^8 - 7Y x 6Y^3
Result: 30X^102 + 3Y^8 - 42Y^4
[Image: SAM_3282.JPG]
And yet another example using huge negative exponents.
It turns out that it doesn't support superscripts on negative exponents, although it changes automatically to conventional algebraic notation.
Simplify 3X^9000 x 7X^-76543
Result: 21 / X^67543
(about 1 second to compute this)
[Image: SAM_3286.JPG]
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - Leonid - 02-23-2017 11:32 AM
I meant by changes font exponent before:
and after calculation:
This can be seen only for "2"?
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - jebem - 02-23-2017 11:54 AM
@Leonid:
You have good eyes and attention to details!
Yes, I see your point.
When using the dedicated key "x^2", it will use a different font for the digit "2" than the one used for all the exponent digits when using the key "x^n".
[Image: SAM_3288.JPG]
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - Leonid - 02-23-2017 12:08 PM
Maybe this was made specifically to highlight for the various algorithms and therefore different calculation accuracy for x^2 vs. x^n(n=2) ?
Check it!)
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - jebem - 02-23-2017 12:43 PM
I have checked a few calculations but it seems that it doesn't matter whether the dedicated square key "x^2" or the natural power key "x^n" are used. The results are the same.
Probably the reason is that a dedicated "x^2" key is faster to use (single key entry) than having to press two keys to get the same entry value ("x^n", "2" ).
Also, using the function "x^Y" (accessed using shift over the same "x^n" key) will also give the same results.
The function key "x^Y" allows to enter real numbers in the exponent, whereas the "x^n" only allows to enter natural digits.
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - damaltor - 02-23-2017 02:54 PM
Oooh now i know what you mean. there is another one of that series which does the same thing. give me a day or two, and i will pull it out of my collection.
Yes, the font is different, because the meaning is somewhat different: The first number two, obtained by the x^2 key, is a finite action (square the number "below" it) and the second two, obtained by x^n, is only a digit in a possibly multi-digit exponent. it is not possible to do "123^20" by pressing "1 2 3 x^2 0", because the two ^2 are not the same. i dont know if there is a technical reason to make the numbers different (and i highly doubt it too), but they have to be distinguished somehow as they are simply not the same. i wonder if that is mentioned in the users manual in any way.
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - jebem - 02-24-2017 02:25 PM
I believe we discussed something similar before for the fx-5000F here.
RE: CASIO fx-5500 Scientific Calculator: The 1st "C.A.S." pocket calculator? - damaltor - 02-27-2017 08:48 AM
Exactly, that is the one i was searching for.
