Save session to the simulator - Printable Version
+--- Thread: Save session to the simulator (/thread-7818.html)
Save session to the simulator - compsystems - 02-24-2017 01:51 PM
Hi, to save the current session, I perform, CALCULATOR then EXIT
If the simulator is locked, reset or closed, variables and programs are often maintained, but the history appears in the last saved session (losing the current data in the history view)
Then a new CALCULATOR/SAVE SESSION submenu is required
This is available for example in emu48 and TIEMU
[Image: calculatorState_image00.png]
Test, please put the following expression, the simulator is locked, you have to close it and when you open the expression is lost
purge(x,y);
solve(x^2+((3*y/2)-√(ABS(x)))^2=2-(1/(2*2)),y);
RE: Save session to the simulator - Han - 02-24-2017 04:03 PM
It does not seem to lock up for me. I get
{1/9*(3*√(-4*x^2+7)+6*√(abs(x))),1/9*(-3*√(-4*x^2+7)+6*√(abs(x)))}
or
\[ \left\{\frac{1}{9} \cdot (3 \sqrt{-4\cdot x^{2}+7}+6 \sqrt{\mathrm{abs}\left(x\right)}),\frac{1}{9} \cdot (-3 \sqrt{-4\cdot x^{2}+7}+6 \sqrt{\mathrm{abs}\left(x\right)})\right\} \]
RE: Save session to the simulator - compsystems - 02-24-2017 05:53 PM
purge(x,y);
solve(x^2+((3*y/2)-√(ABS(x)))^2=2-(1/(2*2)),y); [enter] lock, Happens by setting flag: use i.
Is this an important idea?
Save session ...
To see the expressions in pretty-print in this forum was also very good idea to incorporate the simulator or virtual calculator
EDIT COPY as LATEX, etc.
RE: Save session to the simulator - Han - 02-24-2017 07:33 PM
(02-24-2017 05:53 PM)compsystems Wrote:  Happens by setting flag: use i.
Save session ...
I agree that being able to manually save the state is a good feature to have. I believe that this can be achieved by simulating an OFF by pressing [Shift][On] (I have not tested it). Having an option in the menu would be nice.
Quote:To see the expressions in pretty-print in this forum was also very good idea to incorporate the simulator or virtual calculator
This is already available. Just use the latex() command in the HP Prime.
RE: Save session to the simulator - compsystems - 02-24-2017 07:55 PM
This forum supports latex? Or only mathjax?
RE: Save session to the simulator - Han - 02-24-2017 08:32 PM
(02-24-2017 07:55 PM)compsystems Wrote:  This forum supports latex? Or only mathjax?
It supports latex (and mathjax, too, I think). For latex, you can use:
\(  ... insert latex code ... \)
or
\[ ... insert latex code ... \]
The ()'s version will place the expressions in-line with the text. The []'s version will place the expression in its own display line.
