Possible problem with reset values (INPUT CMD) - Printable Version
+--- Thread: Possible problem with reset values (INPUT CMD) (/thread-7885.html)
Possible problem with reset values (INPUT CMD) - compsystems - 03-06-2017 12:21 PM
Hello
1: run testInputList ()
2: then press the backspace key [<-], appears in the first field {4}, which is the value of reset_values
3: then press OK, a (!) appears, Why?
4: now if you press [edit], then [ok] and then another [ok] already accept it
PHP Code:
export testInputList()
begin
  local a
bc;
local resetVAL_aresetVAL_bresetVAL_c;
local initVAL_ainitVAL_binitVAL_c;
initVAL_a := {1}; initVAL_b := {2}; initVAL_c := {3};
resetVAL_a := {4}; resetVAL_b := {}; resetVAL_c := {};
local ObjectType_List :=  6;
local ObjectType := ObjectType_List;
local title := "Type Allow: List {}";
local ok := true;
local cancel := false;
local keyPressedOnMenu := cancel;
keyPressedOnMenu := input
a, [ ObjectType ] },
b, [ ObjectType ] },
c, [ ObjectType ] }
title,
"label_a:""label_b:","label_c:" },
"help_a""help_b""help_c" },
resetVAL_aresetVAL_bresetVAL_c },
initVAL_ainitVAL_binitVAL_c }
  if
keyPressedOnMenu == ok then
return( { ab} );
  else
    return
"Done";
end;
end
RE: Possible problem with reset values (INPUT CMD) - compsystems - 03-13-2017 10:48 PM
Resetting all the fields [shift],[clear], works well, this implies that there is a problem when resetting a single field
RE: Possible problem with reset values (INPUT CMD) - Carlos295pz - 03-14-2017 02:11 AM
True, this should be fixed
RE: Possible problem with reset values (INPUT CMD) - compsystems - 03-14-2017 04:45 PM
A similar problem
HOME MODE
Z3: = 4 + 8 * i; [Enter]
[SHIFT]+[MEM] USER VARS
Z3 [EDIT] [OK] (!) ?
now
(4,8) [OK] I think that the input view should not be closed, a second [OK] returns to the list of variables
[EDIT] 4 + 8 * i;
[EDIT] [OK] (!) ?
RE: Possible problem with reset values (INPUT CMD) - chromos - 03-14-2017 08:18 PM
(03-14-2017 04:45 PM)compsystems Wrote:  HOME MODE
now
[EDIT] 4 + 8 * i;
[EDIT] [OK] (!) ?
It is interesting that Ans in Memory Manager does accept editing of complex number (from 4+8*i to 4+9*i for example) but then Memory Manager shows Ans (Function) instead of Ans (Complex).
