Calculate Euler's number by limit-function - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Calculate Euler's number by limit-function (/thread-7889.html) |
Calculate Euler's number by limit-function - Maro - 03-06-2017 10:17 PM When calculating the following limit in CAS mode \( \lim_{x \rightarrow \infty}(1+\frac{1}{x})^x = e = 2.71828...\) the Prime gives "1" as result (which is wrong) instead of the Euler's number. When doing the same with the 50g there is no problem. Any idea? RE: Calculate Euler's number by limit-function - Arno K - 03-06-2017 10:35 PM Mine gives "e", perhaps there is something stored in x? Arno RE: Calculate Euler's number by limit-function - Marcel - 03-06-2017 11:49 PM Hi! My Prime also give 1... I change the setting and always the same response. Marcel RE: Calculate Euler's number by limit-function - Marcel - 03-06-2017 11:59 PM Hi again! You have to enter it correctly! Check this image and the prime give "e". Marcel RE: Calculate Euler's number by limit-function - Carlos295pz - 03-06-2017 11:59 PM It may be due not to enter the whole expression inside the parenthesis, to do it outside is not considered within the limit. . RE: Calculate Euler's number by limit-function - Maro - 03-07-2017 06:35 AM Thanks to all experts here! Indeed it was the parentheses Regards Maro RE: Calculate Euler's number by limit-function - parisse - 03-07-2017 12:41 PM Additional parenthesis around the limit as argument of a power would probably clarify... Or use algebraic input. RE: Calculate Euler's number by limit-function - mark4flies - 03-10-2017 10:31 PM (03-06-2017 11:59 PM)Marcel Wrote: Hi again! Wait! You have to enter it 'correctly?' Insane. |
