Display for Voyager / HP-15C - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Display for Voyager / HP-15C (/thread-7896.html) |
Display for Voyager / HP-15C - ormembar - 03-07-2017 09:19 AM Hello, I have a HP-15C with serial no. 2438B Unfortunately the display is damaged and slowly bleeding to death. There was an article on compatible displays from other Voyager models but I cannot find it. Can someone please point me to it (or tell me which calculators are compatible)? Kind regards Andreas RE: Display for Voyager / HP-15C - rprosperi - 03-07-2017 03:39 PM (03-07-2017 09:19 AM)ormembar Wrote: Hello, Any display of a compatible vintage Voyager can be used, so look for a cheap 12C on auction sites. Verify the same vintage/design as yoyr 15C by checking the type of battery contacts; it's more reliable than using serial numbers. The earliest Voyagers had small nearly flat contacts on both sides with clear plastic battery retainers again on both sides. The later ones had a coil spring and clear retainer only on the left side (looking from rear with bat at top). RE: Display for Voyager / HP-15C - ormembar - 03-07-2017 03:49 PM (03-07-2017 03:39 PM)rprosperi Wrote: The earliest Voyagers had small nearly flat contacts on both sides with clear plastic battery retainers again on both sides. The later ones had a coil spring and clear retainer only on the left side (looking from rear with bat at top). So that is what I have to look for? - Sounds good - I have a 16C with the same design - or is that a waste? RE: Display for Voyager / HP-15C - hth - 03-07-2017 06:37 PM Yes, that is a waste. Håkan (03-07-2017 03:49 PM)ormembar Wrote: So that is what I have to look for? - Sounds good - I have a 16C with the same design - or is that a waste? RE: Display for Voyager / HP-15C - anetzer - 03-07-2017 07:09 PM (03-07-2017 03:49 PM)ormembar Wrote: I have a 16C with the same design - or is that a waste? I guess there's more than one member here who would graciously swap an HP-15C for a working HP-16C and throw in an HP-12C without a hesitation... .-) RE: Display for Voyager / HP-15C - grsbanks - 03-08-2017 12:45 PM Definitely a waste! A lot of us would give our left nut to get our hands on a working 16C RE: Display for Voyager / HP-15C - ormembar - 03-08-2017 01:34 PM Since ebay is full of fictuous prices: What would be a reasonable price for a 12C and a 16C? RE: Display for Voyager / HP-15C - SlideRule - 03-08-2017 10:39 PM (03-07-2017 07:09 PM)anetzer Wrote: I guess there's more than one member here who would graciously swap an HP-15C for a working HP-16C and throw in an HP-12C without a hesitation....-) PM sent SlideRule RE: Display for Voyager / HP-15C - Alejandro Paz(Germany) - 03-09-2017 11:32 AM I recently paid (like 2 or 3 months ago) 25 € for a working 12C from '88. I was planning on taking it apart and re-use the keys... the PCB is held in place with those plastic retainers.... one way calcs are they . |
