EXPORT MIXTURE()
//HFormat:=1; HDigits:=7;
LOCAL A,U,M,N1,N2,N3,C1,C2;
LOCAL C3,L1,M1,K1,K2,X5,FLAG;
REPEAT
PRINT();
INPUT({{U,[2]},{M,[2]}},"UNITS AND DENOMINATION",{"UNITS","DENOM"},{"LBS, OZ, ETC.","DOLLARS, CENTS, ETC."});
INPUT({N1,C1},U+","+M+" PER "+U+"-FIRST ITEM",{"N1","C1"},{"IF A QUANTITY IS UNKNOWN, ENTER ZERO","IF A QUANTITY IS UNKNOWN, ENTER ZERO"});
INPUT({N2,C2},U+","+M+" PER "+U+"-SECOND ITEM",{"N2","C2"},{"IF A QUANTITY IS UNKNOWN, ENTER ZERO","IF A QUANTITY IS UNKNOWN, ENTER ZERO"});
INPUT({N3,C3},U+","+M+" PER "+U+"-MIXTURE");
FLAG:=0;
A:=(C1+C2)/2;
IF N1==0 AND N2==0 THEN
IF A<=C3 THEN
L1:=N3/2;
M1:=N3;
ELSE
L1:=0;
M1:=N3/2;
K2:=N3*C3;
FOR X:=L1 TO M1 STEP .1 DO
IF X*C1+(N3-X)*C2==N3*C3 THEN
N1:=X;
N2:=N3-X;
FLAG:=1;
BREAK;
K1:=N3*C3-X*C1-(N3-X)*C2;
IF ABS(K1)<=ABS(K2) THEN
K2:=K1;
X5:=X;
IF FLAG==0 THEN
IF IP(X5+.0001)==IP(X5+.001) THEN N1:=IP(X5+.001) ELSE N1:=X5;END;
N2:=N3-N1;
FLAG:=1;
ELSE
IF N1==0 AND N3==0 OR N2==0 AND N3==0 THEN
IF N2:=0 THEN
C1:=C2;
N1:=N2;
K2:=N2*C2*100;
IF A<=C3 THEN
L1:=0;
M1:=N2;
ELSE
L1:=N2;
M1:=(100*N2);
IF X*C1+N2*C2==(N2+X)*C3 THEN
N1:=X;
N3:=N1+N2;
FLAG:=1;
BREAK;
K1:=(N2+X)*C3-X*C1-N2*C2;
K2:=K1;
X5:=X;
IF FLAG==0 THEN
IF IP(X5+.0001)==IP(X5+.001) THEN N1:=IP(X5+.001);ELSE N1:=X5;END;
N3:=N2+N1;
FLAG:=1;
IF FLAG==0 THEN
IF N1==0 THEN N1:=(N3*C3-N2*C2)/C1;END;
IF N2==0 THEN N2:=(N3*C3-N1 *C1)/C2;END;
N3:=N1+N2;
IF C3==0 THEN C3:=(N1*C1+N2*C2)/N3;END;
PRINT("MIX "+N1+" "+U+" AT "+C1+" "+M+" PER "+U);
PRINT("WITH "+N2+" "+U+" AT "+C2+" "+M+" PER "+U);
PRINT("TO GET A MIXTURE OF "+N3+" "+U+" AT "+C3+" "+M+" PER "+U);
WAIT;
INPUT({{A,[2]}},"ANYTHING ELSE (YES OR NO)?");
UNTIL UPPER(A)=="NO";
