Green background with GetKey Problem!? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Green background with GetKey Problem!? (/thread-7966.html) |
Green background with GetKey Problem!? - Onieh - 03-17-2017 03:46 PM RE: How make a green Background by a Choose Funktion okay, what is with this Solution. But i don't why the Program leave the Repeat-Until Funktion when i press 1, repeat1.. or 2, repeat 2.. or 3 and repeat 3..? EXPORT NewInput() BEGIN RECT_P(0,0,320,220,RGB(0,255,0)); TEXTOUT_P("F L U G N A V I G A T I O N",31,20,7,RGB(255,255,255)); TEXTOUT_P("Press 1 für: ICAO",70,70); TEXTOUT_P("Press 2 für: POSITION",70,100); TEXTOUT_P("Press 3 für: FLUGSTRECKE",70,130); TEXTOUT_P("Press Del für Abbruch",70,160); REPEAT K:=GETKEY; IF K==42 THEN PRINT("ICAO"); END; //KEY Test IF K==43 THEN PRINT("POSITION"); END; //KEY TEST IF K==44 THEN PRINT("FLUGSTRECKE"); END; //KEY TEST UNTIL K==19; STARTVIEW(-1); END; RE: Green background with GetKey Problem!? - eried - 03-17-2017 04:22 PM Rethink UNTIL K==19; line RE: Green background with GetKey Problem!? - Onieh - 03-17-2017 04:31 PM What do you mean? RE: Green background with GetKey Problem!? - Onieh - 03-17-2017 04:48 PM Do you mean UNTIL K==19 or K==42 or K==43 or K== 44; RE: Green background with GetKey Problem!? - eried - 03-17-2017 06:52 PM (03-17-2017 04:48 PM)Onieh Wrote: Do you mean That is an option RE: Green background with GetKey Problem!? - Onieh - 03-17-2017 09:46 PM And the other one? |
