Windows keyboard layout for the HP Prime - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Windows keyboard layout for the HP Prime (/thread-7978.html) |
Windows keyboard layout for the HP Prime - Eric Rechlin - 03-19-2017 04:38 AM I have created a new Windows keyboard layout intended to facilitate typing the special symbols used on the HP Prime. It is based on the regular United States layout, but it adds support for the "AltGr" (right Alt) key to type the special characters. When this keyboard layout is active, your right Alt key (the AltGr key) now allows you to type special characters. The following are available: Code:
You can also type the following characters, but due to limitations, possibly caused by both of these characters being in the "Private Use" area, I can't get them to work with the HP Connectivity Kit, but they do work fine in the HP Prime Virtual Calculator: Code:
Additionally, the following keys are setup as "dead keys". This means that after you press them, the next character typed will show that character with the specified diacritical mark on it, if available. Code:
For example, AltGr-Shift-/ followed by Shift-L gives Ł, and AltGr-' followed by E gives é. Here's a graphical view of the general layout: I've added this to my site at http://www.hpcalc.org/details/7853 RE: Windows keyboard layout for the HP Prime - compsystems - 04-02-2017 12:33 PM Very useful, As I could create, a similar for a keyboard other than ENGLISH |
