From 6 single program blocks make one Program!? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: From 6 single program blocks make one Program!? (/thread-8040.html) |
From 6 single program blocks make one Program!? - Onieh - 03-27-2017 10:13 AM How can I create from 6 single program blocks a single with jump address like in Basic the GOTO statement? RE: From 6 single program blocks make one Program!? - Didier Lachieze - 03-27-2017 11:23 AM If you want to simulate the GOTO statement you can use a loop like this one: Code: EXPORT Test() The variable Line is simulating the BASIC line number, each bloc is executed depending on the value of Line and at the end of each block you have to set Line to the value of the next bloc to be executed, this way you can “jump” to the line number you want. You exit the sequence by setting Line to 0. This should work but it is pretty cumbersome. It may be better to change your code to avoid the need of GOTO. See here for the original idea. RE: From 6 single program blocks make one Program!? - DrD - 03-27-2017 12:22 PM Since you have 6 single program blocks, would configuring them as subroutines work for you? You can then "goto" them by using their program name. Here's a little example: Code:
RE: From 6 single program blocks make one Program!? - Onieh - 03-29-2017 07:13 AM @ Didier, Thanks for your suggestions, which are great! |
