Longest computation that your calculator performed for you? - Printable Version
+--- Thread: Longest computation that your calculator performed for you? (/thread-8066.html)
Pages: 1 2
RE: Longest computation that your calculator performed for you? - John Keith - 04-01-2017 11:24 PM
Longest ever for me were larger instances of the 8 queens problem on a 71B. The largest was 256 queens which took about 24 hours, and that was with the inner loop coded in assembly!
I also did several fractals on the 71B printed directly to the 2225B Thinkjet printer. They took several hours each IIRC.
RE: Longest computation that your calculator performed for you? - factor - 04-02-2017 04:44 AM
Was doing some overclocking comparisons among TI and Casio calcs, the "benchmark" took the longest to finish is a GARCH parameter estimation on Nspire with a data set of 1000 sample from S&P500 index. Took more than 2 hours.
https://gmgolem.wordpress.com/2015/01/22/estimating-garch-parameters-from-sp500-index-data-in-nspire/
RE: Longest computation that your calculator performed for you? - pier4r - 04-02-2017 08:30 AM
(04-02-2017 04:44 AM)factor Wrote:  Was doing some overclocking comparisons among TI and Casio calcs, the "benchmark" took the longest to finish is a GARCH parameter estimation on Nspire with a data set of 1000 sample from S&P500 index. Took more than 2 hours.
Interesting inputs in the article, I'll analyze later.
Thanks for sharing!
