WP34S USB and IR board release - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP34S USB and IR board release (/thread-8077.html) |
RE: WP34S USB and IR board release - rprosperi - 02-23-2018 04:20 AM Thanks for the update Jim! No need to apologize, we all appreciate your squeezing this into your real life. When it's convenient is fine, we'll be here when you're ready. Thanks! RE: WP34S USB and IR board release - Harald - 02-23-2018 08:17 AM Hi Jim, sorry for giving you headaches. I never generated gerber files myself, so I don't have them. My suppliers were always able to accept the eagle *.brd files and generate Gerbers themselfs. Maybe your supplier can too? Cheers, Harald (02-23-2018 12:42 AM)Jim Horn Wrote: I'm working on ordering the boards. The files from Harald are for the Eagle PCB software. It is needed to create the needed Gerber format files. So I've downloaded and am learning same. Should be quick. I've not used Eagle before but have used many others. RE: WP34S USB and IR board release - Jim Horn - 02-24-2018 01:13 AM Oh, heavens, Harald - no need for sorrow! I'm just delighted that you made the files available that you did! I've always been curious about Eagle, having used a dozen or so such tools through the years. And now I get to play with it. That's a feature, not a bug! Thanks again for a fine design! Jim (02-23-2018 08:17 AM)Harald Wrote: Hi Jim, RE: WP34S USB and IR board release - Jlouis - 07-18-2018 04:14 PM Hello! How is that project going? Is it finished? I'm still interested. TIA Cheers! RE: WP34S USB and IR board release - burkhard - 07-18-2018 06:23 PM (07-18-2018 04:14 PM)Jlouis Wrote: I'm still interested. Me too! I love my WP34Ss (plural!) RE: WP34S USB and IR board release - 2far - 09-05-2018 08:57 AM I'm still interested as well, with my WP34S and WP31S at work, and another one at home :-) Really appreciate the effort! RE: WP34S USB and IR board release - Christobaldo - 09-14-2018 09:26 AM I inadvertently bricked my 34S and would like to build a new one.... Any news .. I would be really interested by a board assembled or to be soldered. RE: WP34S USB and IR board release - burkhard - 09-14-2018 01:29 PM (09-14-2018 09:26 AM)Christobaldo Wrote: I inadvertently bricked my 34S and would like to build a new one.... I've had bad flashes before (because of the jury-rigged way I do it without the proper cable... no fault of the firmware or software tools), wherein it sure looks dead. After I couple of tries, though, I'm back in business and everything is fine. Are you really sure it is bricked? From what I have read here from the experts, they seem to be pretty tolerant of just about anything going awry in flashing. Good luck with it...the WP34S is such a neat collaborative project. Now if we could only start turning the mountain of plentiful (=cheap) used modern ARM processor 12C calculators into 15C and 16C machines :-) I wish I had the skills. RE: WP34S USB and IR board release - burkhard - 09-14-2018 01:41 PM PS -- If you are having troubles with the flashing or seem to have bricked it, you might want to try putting brand new batteries in and carefully repeating the flashing process. Batteries that could be fine for running the calculator are not necessary up to the demands of flashing... they are loaded pretty hard during that. I do recall having this problem myself once. Here's a good old link on the subject of seemingly bricking an HP30b during flash to WP34S: http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv020.cgi?read=191168#191168 RE: WP34S USB and IR board release - Ninguis - 10-14-2018 06:25 AM Does any one have the connection wiring diagram for Haralds IR board the link in this forum doesn't work anymore? cheers Don RE: WP34S USB and IR board release - Mark Hardman - 10-14-2018 07:03 PM (10-14-2018 06:25 AM)Ninguis Wrote: Does any one have the connection wiring diagram for Haralds IR board the link in this forum doesn't work anymore? The version 3.1 manual covers the installation of a Haralds board and is available on Source Forge. Ref: https://sourceforge.net/projects/wp34s/files/doc/Manual_wp_34s_3_1.pdf/download RE: WP34S USB and IR board release - Ninguis - 10-15-2018 06:34 AM Thank you i found it in the vwesio 3.1 online, I have the version 3.3 hardcopy no mention of the connections. cheers Don RE: WP34S USB and IR board release - Harald - 11-05-2018 03:38 PM I have had a request for the eagle data for the HP flash cable USB conversion PCB and have added a zip file to the first post. Cheers, Harald RE: WP34S USB and IR board release - jpcuzzourt - 10-03-2019 12:27 AM Hi, Are kits still available? I'm in the US. I'm late to the party, but getting ready to flash my first WP-34S. I have a second calculator on the way also, so I think I'd like to get two (2) kits with crystal and caps, and IR diode. Please let me know what current price and availability is and whom I should contact. Thank you so much. This is a wonderful project. I'm a ChE, disabled and thus retired. But I need to try to keep my brain busy with what I can. RE: WP34S USB and IR board release - Jaco@cocoon-creations.com - 10-03-2019 07:12 AM (10-03-2019 12:27 AM)jpcuzzourt Wrote: Hi, Hi I am also interested in two usb boards. What is the path of least resistance to get hold of either a kit or boards? Regards Jaco RE: WP34S USB and IR board release - Harald - 10-03-2019 07:45 PM I think nobody has made any further boards after mine have run out. Someone has ordered A LOT of bare boards a long time ago. Not sure if those are still hidden in some drawer... Maybe they will become available... Alternatively I could probably make new boards if enough people are interested and commit to buying. I think of we get 10+ boards it is feasible. Cheers, Harald RE: WP34S USB and IR board release - Jaco@cocoon-creations.com - 10-03-2019 07:48 PM (10-03-2019 07:45 PM)Harald Wrote: I think nobody has made any further boards after mine have run out. Hi Harald. I commit for two. Populated if possible. Otherwise bare. J RE: WP34S USB and IR board release - burkhard - 10-03-2019 08:29 PM (10-03-2019 07:45 PM)Harald Wrote: Alternatively I could probably make new boards if enough people are interested and commit to buying. I think of we get 10+ boards it is feasible. I would likewise be thrilled to order two, either pre-built or if need be, as kits. I do like my WP34Ss ! RE: WP34S USB and IR board release - brierand - 10-03-2019 11:31 PM I would commit to 2 complete kits, preferably assembled. RE: WP34S USB and IR board release - ctrclckws - 10-04-2019 11:59 AM Add two more, assembled if possible Edward |
