Should I bother? HP-34C in rough shape - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Should I bother? HP-34C in rough shape (/thread-8161.html) |
RE: Should I bother? HP-34C in rough shape - AndiGer - 04-28-2017 03:32 AM I think you can. But be sure you remember the polarity of the batteries. An idea: Just release one side of the metal plate. This way a charger can hold both batteries anyway. So you know how to reinsert after charging. Andi RE: Should I bother? HP-34C in rough shape - pier4r - 04-28-2017 09:38 AM Had Adam success with his 34c? RE: Should I bother? HP-34C in rough shape - dm123 - 05-12-2018 10:13 PM Hi all, Sorry for reviving an old thread. I’m just getting to the bypass on my unit, a year later. Life’s interruptions..... My question is to Geoff or anyone else who is familiar with the 34C spice power strip byass. I practiced my soldering skills, and had a question before attempting the solder. The -ve pin on the board is very small (pin 6). Is it ok to shove the stripped portion of the wire through the little hole to help position the wire prior to the solder?. Otherwise , I don’t know how to position the wire without a second person hold the wire for me. I can get a second person to help hold the wire. Also, when soldering to the terminals, per Geoff’s photograph, should one shove the stripped portion of the wire through the hole and then solder, or try to solder directly onto the circular metal contact? My last question is for tearing off the old cracked power strip. Can one just cut it close to the pcb board and leave the part on the pcb board intact. Same with the part that goes to the terminals, leave the overlay of the strip on the terminal board but trim it close to the board. I’d rather do less than more in trearing off the old power strip, if possible. Thanks RE: Should I bother? HP-34C in rough shape - brickviking - 05-13-2018 01:37 AM I was a bit ambivalent about voting on this, given I can see both sides of the equation. However, I voted "Yes". So, first the list of pro's.
Now for my short list of cons:
soldered models, not the earlier press-fit models. (Post 218) RE: Should I bother? HP-34C in rough shape - dm123 - 05-13-2018 05:19 AM (05-13-2018 01:37 AM)brickviking Wrote: I was a bit ambivalent about voting on this, given I can see both sides of the equation. However, I voted "Yes". Thanks Viking. Regarding the batteries, I know it’s not recommended, but I “flattened” some of my AA rechargeable with a towel over the battery and a hammer. I know it’s not advised, but it did work in flattening the batteries so that they fit in easily. “Batteries might have to be "retro-fitted" or sourced with flat tops so they fit the battery holder. Those batteries will probably have to be charged in an external charger, instead of relying on the slow trickle-charge of the original power pack” Is there a place that sells battery holders that bridge the one side of the pair, like the original holders did, and at the same time allow you to slide out the batteries so that they can be recharged. I’m trying to find out if there is an easy solution to this. I could not find any battery holders like this. This would be the bast solution Also, another idea I had, is if one could stick a conducting plate on the nonterminal side of the battery compartment of the calculator so that the batteries could be imsertd right into the compartment directly.(with correct polarities ,right directions) Negative Positive Positive. Negative I could not find any chargers that charge a bound battery pack as a pair, which is the third option,,given that the bound packs are available on eBay. RE: Should I bother? HP-34C in rough shape - brickviking - 05-13-2018 05:43 AM (05-13-2018 05:19 AM)dm123 Wrote: Is there a place that sells battery holders that bridge the one side of the pair, like the original holders did, and at the same time allow you to slide out the batteries so that they can be recharged. I’m trying to find out if there is an easy solution to this. I could not find any battery holders like this. This would be the best solution. I'd agree wholeheartedly with this, given that modern methods now allow for perhaps 3d-printing them up. (05-13-2018 05:19 AM)dm123 Wrote: Also, another idea I had, is if one could stick a conducting plate on the nonterminal side of the battery compartment of the calculator so that the batteries could be imserted right into the compartment directly.(with correct polarities, right directions) I actually found I could unbond the two batteries for charging, though I suspect it's not easy. I don't remember exactly how it was done, given that it was 1994. From what I remember, it's a metal framework around a plastic centre, with two slots for the batteries and one end free, exposing the two relevant ends. Obviously plugging the batteries back into the cradle the right way around is essential. If you can find the solution you mentioned above, that would be the best way around, but you'll still need a metal plate bridging one end. (Post 219) RE: Should I bother? HP-34C in rough shape - Zaphod - 05-13-2018 06:26 AM (05-13-2018 05:19 AM)dm123 Wrote: Is there a place that sells battery holders that bridge the one side of the pair, like the original holders did, and at the same time allow you to slide out the batteries so that they can be recharged. I’m trying to find out if there is an easy solution to this. I could not find any battery holders like this. This would be the bast solution This manufacturer I found does a plethora of battery terminals and plates (they also do cell holders too) http://www.keyelco.com/category.cfm/Battery-Coin-Cell-Holders-Contacts-Clips/Cylindrical-Cell-Contacts/p/404/id/410 They are stocked by most of the big distributors (Mouser, Digi , RS and Farnell etc). RE: Should I bother? HP-34C in rough shape - Dieter - 05-13-2018 08:31 AM (05-13-2018 05:19 AM)dm123 Wrote: Regarding the batteries, I know it’s not recommended, but I “flattened” some of my AA rechargeable with a towel over the battery and a hammer. "Not recommended" is not quite the correct term here... #-\ (05-13-2018 05:19 AM)dm123 Wrote: Is there a place that sells battery holders that bridge the one side of the pair, like the original holders did, and at the same time allow you to slide out the batteries so that they can be recharged. I’m trying to find out if there is an easy solution to this. I could not find any battery holders like this. This would be the bast solution FWIW, here is my "best solution" for the 34C: Take a lok in the battery compartment. On the left you'll find the two contacts for + and – while on the right hand side there is a small metal plate – if I remember correctly, I may be wrong here. I removed this plate (if there was one ;-)) and replaced it with a piece of aluminum foil, folded several times. This way two standard Sanyo/Panasonic Eneloop AA cells (with standard button top) fit nicely into the compartment. You can do even better if you replace the aluminum foil with something more suitable. (05-13-2018 05:19 AM)dm123 Wrote: Also, another idea I had, is if one could stick a conducting plate on the nonterminal side of the battery compartment of the calculator so that the batteries could be imsertd right into the compartment directly.(with correct polarities ,right directions) Exactly – I see you got the idea. ;-) (05-13-2018 05:19 AM)dm123 Wrote: I could not find any chargers that charge a bound battery pack as a pair, which is the third option,,given that the bound packs are available on eBay. A battery pack with 2xAA is a standard item that can be found in any decent eletronics store. There are also battery specialists that will build any pack you like from any cells you want. You'll also find smart chargers that are suitable for packs from, say, 1 to 6 cells. These are common items in the RC model world (cars, airplanes etc.), but the most chargers may be overkill for your application. The solution with two standard AAs and a thin metal connection works fine for me. Dieter RE: Should I bother? HP-34C in rough shape - AndiGer - 05-13-2018 11:39 AM For charging a connected pair of flattops I simply modified a broken hair cutting machine that contained 2 AA cells. Just use the charger and broke away some plastic parts of the "battery case".[attachment=5931] RE: Should I bother? HP-34C in rough shape - dm123 - 05-13-2018 06:50 PM (05-13-2018 08:31 AM)Dieter Wrote:(05-13-2018 05:19 AM)dm123 Wrote: Regarding the batteries, I know it’s not recommended, but I “flattened” some of my AA rechargeable with a towel over the battery and a hammer. Hi Dieter, thanks for your suggestions. Unfortunately there is no metal plate on the 34c, as the original hp battery pack was what bridged the two nonterminal sides of the battery. They sell these packs on eBay, and Andy has a recharger that works with the bound batteries. My recharger has a very thick separator between battery insertions and won’t work unless I break the batteries apart. I do have aluminum foil tape and used that on the nonterminal side of the 34c battery compartment, but it tears easily when taking out and inserting the batteries. I’m looking at the other link just sent out at this battery supply place and looking for a thin plate option, to be glued (? Not sure if this is safe due to heat) to the nonterminal side . http://www.keyelco.com/category.cfm/Terminal-Strips/Standard-Lug-Type/p/509/id/511/c_id/771 RE: Should I bother? HP-34C in rough shape - Zaphod - 05-13-2018 07:04 PM What about: http://www.keyelco.com/category.cfm/Slide-In-Battery-Contacts/Slide-In-AA-Battery-Contacts/p/1039/id/1218 RE: Should I bother? HP-34C in rough shape - dm123 - 05-13-2018 08:03 PM (05-13-2018 07:04 PM)Zaphod Wrote: What about: Thanks. I think I found a good option. https://www.amazon.com/Tenergy-2000mAh-Rechargeable-Battery-Trimmers/dp/B007KMC9BO/ref=pd_sbs_23_4?_encoding=UTF8&pd_rd_i=B007KMC9BO&pd_rd_r=CDB11WKPGWD6YXPAYDV5&pd_rd_w=dlAu9&pd_rd_wg=AY4D2&refRID=CDB11WKPGWD6YXPAYDV5&th=1 These are flat heads. Both batteries come with the metal tab already soldered to negative. I would bend the tab out on one (they have a picture of the folded metal tab in the 5th photo). I could leave it bent out and it would still insert into the charger. So would not have to keep bending it back and forth. Inserting it into the 34c would work fine as the tight fit would cause the other battery to contact. So insertion would be Top battery. Negative (leave tab bent in or remove) ———-positive Bottom battery. Positive——————————————————negative (bend tab out) https://www.amazon.com/Tenergy-2000mAh-Rechargeable-Battery-Trimmers/dp/B007KMC9BO/ref=pd_sbs_23_4?_encoding=UTF8&pd_rd_i=B007KMC9BO&pd_rd_r=CDB11WKPGWD6YXPAYDV5&pd_rd_w=dlAu9&pd_rd_wg=AY4D2&refRID=CDB11WKPGWD6YXPAYDV5&th=1 RE: Should I bother? HP-34C in rough shape - Dieter - 05-13-2018 08:06 PM (05-13-2018 06:50 PM)dm123 Wrote: Hi Dieter, thanks for your suggestions. Unfortunately there is no metal plate on the 34c, as the original hp battery pack was what bridged the two nonterminal sides of the battery. Yes, I remember. (05-13-2018 06:50 PM)dm123 Wrote: They sell these packs on eBay, and Andy has a recharger that works with the bound batteries. My recharger has a very thick separator between battery insertions and won’t work unless I break the batteries apart. What kind of charger is this? And how does it charge the batteries, i.e. what kind of charge control is used? (05-13-2018 06:50 PM)dm123 Wrote: I do have aluminum foil tape and used that on the nonterminal side of the 34c battery compartment, but it tears easily when taking out and inserting the batteries. You have to fold it a few times so that you get, say, a four layer insert. ;-) I have had no problems with inserting and removing the batteries. At least not in the last ten years. (05-13-2018 06:50 PM)dm123 Wrote: I’m looking at the other link just sent out at this battery supply place and looking for a thin plate option, to be glued (? Not sure if this is safe due to heat) to the nonterminal side. That's another option – something like "aluminum foil deluxe". ;-) Maybe you don't even have to permanently attach it to the case at all. (05-13-2018 06:50 PM)dm123 Wrote: http://www.keyelco.com/category.cfm/Terminal-Strips/Standard-Lug-Type/p/509/id/511/c_id/771 I can't see how one of these parts may be of any use for this application. The link Zaphod posted looks more promising: take a look at part #5227. There also is a datasheet with the exact dimensions, e.g. the thickness (1,2 mm). But I doubt they will sell you a single piece of this. Maybe you can build something similar yourself. Dieter RE: Should I bother? HP-34C in rough shape - Zaphod - 05-13-2018 09:00 PM (05-13-2018 08:06 PM)Dieter Wrote: I can't see how one of these parts may be of any use for this application. The link Zaphod posted looks more promising: take a look at part #5227. There also is a datasheet with the exact dimensions, e.g. the thickness (1,2 mm). But I doubt they will sell you a single piece of this. Maybe you can build something similar yourself. Digikey will sell you just one (with a handling charge of course) https://www.digikey.co.uk/product-detail/en/keystone-electronics/5227/36-5227-ND/2342488 Mouser too: https://www.mouser.co.uk/ProductDetail/Keystone-Electronics/5227?qs=fP5bVVCrK%2fczqonEdMH0JQ== Of course if you're ordering along with other stuff and get it over their threshold you'll pay no handling charge.... (maybe get someone who uses them a lot to order one for you ) I'm waiting myself to build an order up past £33 so I can add some part 181 AAA spring terminals for that Sharp pocket computer I received with corroded terminals RE: Should I bother? HP-34C in rough shape - dm123 - 05-15-2018 01:18 AM Hi all,, I did the soldering and wiring, but how can one get the bottom cover back on? The wires get in the way of the top ( terminal board) sliding into the bottom housing. Thanks |
