Plotting result of Lagrange function - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Plotting result of Lagrange function (/thread-8195.html) |
Plotting result of Lagrange function - tdh79 - 04-18-2017 04:33 PM When i use Lagrange to find a polynomial from a matrix it posts the result with lower case x's, when i try to copy this into the function view I get syntax error unless I replace all the x's with X. Is there an easier way to do this? RE: Plotting result of Lagrange function - tdh79 - 04-18-2017 04:48 PM Nevermind, I figured out how to do it in HOME view instead of CAS.. |
