Bug in Complex_vector .^ (-1) [SOLVED] - Printable Version
+--- Thread: Bug in Complex_vector .^ (-1) [SOLVED] (/thread-8270.html)
Bug in Complex_vector .^ (-1) [SOLVED] - JMB - 04-30-2017 09:54 AM
The following command gives a wrong output in HOME (FW 10637, VC 11226):
[i, -i] .^ (-1) → [1-i, 1+i]
In CAS you get the correct answer:
[i, -i] .^ (-1) → [-i, i]
If you use lists instead of vectors, you get the correct result both in HOME and CAS:
{i, -i} .^ (-1) → {-i, i}
RE: Bug in Complex_vector .^ (-1) - cyrille de brébisson - 05-01-2017 05:21 AM
Thanks, we will look at it.
Cyrille
RE: Bug in Complex_vector .^ (-1) - JMB - 05-01-2017 05:31 PM
Thank you for your time, Cyrille!
RE: Bug in Complex_vector .^ (-1) [SOLVED] - JMB - 02-02-2018 08:48 PM
Corrected in firmware 13333.
Thanks to the HP Prime Team!
