INPUT Question... - Printable Version
+--- Thread: INPUT Question... (/thread-838.html)
INPUT Question... - churichuro - 03-07-2014 01:44 AM
Hi
command INPUT use only one column for input values
or exist some procedure for do multiple inputs columns
just like in the FINANCE application ?
thanks.
RE: INPUT Question... - cdodds - 03-07-2014 03:19 AM
The built in Help in the calculator is quite informative.
RE: INPUT Question... - cdodds - 03-07-2014 04:30 AM
INPUT({g1,g2,VPI,VPIE,LENGTH,INT,SSTA}, //variables used
"Verticle Curves", //Title
{" % Grade In "," % Grade Out "," VPI Sta "," VPI Elev"," Length"," Sta Interval","Special Station"}, //Lables for input
{"% Grade In","% Grade Out","VPI Sta","VPI Elev","Length of Curve"," Sta Interval","Enter '0' to Calculate full curve at intervals"}, //Help text to be displayed at bottom of screen
{g1,g2,VPI,VPIE,LENGTH,INT,0}); //Default values for variables, in this case it is whatever is already stored in those variables
Here is where you can find my program to calculate vertical curves:
http://www.hpmuseum.org/forum/thread-73.html
Scroll to the bottom for the latest version.
Hope this helps
RE: INPUT Question... - churichuro - 03-07-2014 09:09 PM
(03-07-2014 03:19 AM)cdodds Wrote:  The built in Help in the calculator is quite informative.
Thanks cdodds, but you did not understand.
I look for undocumented features of the input command.
more like INFORM command in HP50-48-49
may not believe it but I can read the manual for the HP PRIME Smile
on FINANCE application a form input with 2 columns is used, not only one column like in the INPUT command.
seems that the calculator has many features that are not documented.
RE: INPUT Question... - Tim Wessman - 03-07-2014 09:21 PM
(03-07-2014 09:09 PM)churichuro Wrote:  more like INFORM command in HP50-48-49
You do not have that level of control with the current version. That does not mean it will not change in a future one however.
RE: INPUT Question... - churichuro - 03-07-2014 11:19 PM
YES!!! I'm sure about it! thanks Tim.
