HP67 Card read error - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP67 Card read error (/thread-8444.html) |
HP67 Card read error - quaymat321234 - 06-02-2017 05:49 AM Just received a beautifully restored HP67 but have a problem reading clipped cards. They all (including the standard pack cards) give an error. Unclipped cards write and read without any problems. Anyone a suggestion? Regards Qmat RE: HP67 Card read error - PANAMATIK - 06-02-2017 03:03 PM (06-02-2017 05:49 AM)quaymat321234 Wrote: Just received a beautifully restored HP67 but have a problem reading clipped cards. Perhaps the card reader motor has a slightly different speed than original and cannot read the prerecorded cards, but write and read new cards. Bernhard RE: HP67 Card read error - SlideRule - 06-02-2017 04:22 PM (06-02-2017 05:49 AM)quaymat321234 Wrote: ... have a problem reading clipped cards. They all (including the standard pack cards) give an error. Unclipped cards write and read without any problems. Anyone a suggestion?The old 65 Notes contained a novel approach to R/W a clipped magnetic card: a worn / used/ etc. magnetic card was trimmed on the right to MATCH the vertical profile on the left of the target clipped card. The trimmed card was then gently inserted in the card reader slot from the left and the clipped card was inserted from the right. I used this technique, it works! If you have access to the old Notes, the article is thorough and replete with illustrations, etc. If not, I'll elaborate in follow on dialog. I also simply pinched a small piece of tape to the clipped corner with the same success. Both methods worked for me and should help you troubleshoot the clipped vs unclipped mystery. BEST! SlideRule edit: found illustration, see attached png file [attachment=4886] RE: HP67 Card read error - BobVA - 06-02-2017 04:41 PM (06-02-2017 03:03 PM)PANAMATIK Wrote: Perhaps the card reader motor has a slightly different speed than original and cannot read the prerecorded cards, but write and read new cards. That's an interesting hypothesis. If you have a card to spare, perhaps you can clip one that is currently reading OK and see if it still reads correctly? If so, as Bernhard notes, perhaps it's an issue of "old recording" vs. "new recording" rather than "clipped" vs. "not clipped." RE: HP67 Card read error - Geoff Quickfall - 06-08-2017 03:07 PM If a clipped card reader problem (and since it is restored), it would appear maybe the clipped card detector spring, one of the 5 finger springs under the card reader assembly is bent, or the ball that is pressed down to engage the detector spring is missing. You never know how 'restored' a card reader is! |
