Error in CASE doc in manual - Printable Version
+--- Thread: Error in CASE doc in manual (/thread-8464.html)
Error in CASE doc in manual - KeithB - 06-06-2017 07:40 PM
From the pdf manual:
CASE
IF THEN RETURN "negative"; END;
IF THEN RETURN "small"; END;
DEFAULT RETURN "large";END;
I think you need some tests between the "IF" and the "THEN".
RE: Error in CASE doc in manual - Joe Horn - 06-06-2017 11:07 PM
Which version of the document do you have? My copy (Second Edition, September 2016) has this on page 584:
CASE
IF A<0 THEN RETURN "negative"; END;
IF 0≤A≤1 THEN RETURN "small"; END;
RE: Error in CASE doc in manual - Tyann - 06-07-2017 03:34 AM
Bonjour
Je me suis rendu compte que DEFAULT n'est pas obligatoire
( par accident, je l'ai oublié).
Ceci fonctionne.
Hello
I realized that DEFAULT is not mandatory
(By accident, I forgot it).
This works.
CASE
RETURN "large";
RE: Error in CASE doc in manual - KeithB - 06-07-2017 03:03 PM
HPPrime-5-user_guide_en_2015_06_17_1
So I guess I need a new one!
RE: Error in CASE doc in manual - toml_12953 - 06-07-2017 04:40 PM
This code works, too:
CASE
DEFAULT "large";
Tom L
RE: Error in CASE doc in manual - KeithB - 06-07-2017 08:09 PM
I know what is required, I was just pointing out an error in the manual, which appears to have been corrected.
RE: Error in CASE doc in manual - Marcel - 06-09-2017 10:39 AM
Hi Joe,
I only find July 2015 for the book where do you find the "Second edition September 2016" book?
Thank you.
Marcel
OK... I find it!
Sorry...
