bug in debug mode! - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: bug in debug mode! (/thread-8484.html) |
bug in debug mode! - wangchong01 - 06-10-2017 09:13 AM Hello, I have found a bug in the debug system for the calculator. When you debug an app program and press edit, the calculator crashed when you quitted the edit of the program. for example: you write the following codes in an app: EXPORT START() BEGIN DEBUG; 1;//just for not quitting when debugging END; and press edit - yes and Esc button. The calculator then restarts. RE: bug in debug mode! - John Colvin - 06-10-2017 06:09 PM It doesn't crash on my Prime. I am using software version 10637 (8-29-2016). |
