HP48GX RAM card design - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP48GX RAM card design (/thread-8487.html) Pages: 1 2 |
RE: HP48GX RAM card design - Marco Polo - 01-21-2021 04:12 PM (01-21-2021 09:33 AM)wan Wrote: There‘re two gold colored capacitors on the bottom right of the board, these two 440uf capacitors will provide power when changing batteries. They are larger than Paul's original design and provide longer holding time. I think they can hold for more than 20 seconds.Clever design, indeed. Are you sure that 20 seconds are enough? Just as an example, pulling-out the batteries from my Cynox cards requires some effort and doing it within 20 seconds is quite challenging RE: HP48GX RAM card design - wan - 01-22-2021 12:50 AM (01-21-2021 04:12 PM)Marco Polo Wrote: Are you sure that 20 seconds are enough? The Cynox card covers the back half of the battery, so you can only pinch the front half of the battery to remove it. This makes it difficult to remove the battery. My battery holder is bar shaped and the back half of the battery is exposed, so it can be easily pushed out. With a fresh battery ready to go, it takes less than 10 seconds to swap the batteries. RE: HP48GX RAM card design - Jonathan Busby - 01-22-2021 06:33 PM (01-21-2021 04:12 PM)Marco Polo Wrote:(01-21-2021 09:33 AM)wan Wrote: There‘re two gold colored capacitors on the bottom right of the board, these two 440uf capacitors will provide power when changing batteries. They are larger than Paul's original design and provide longer holding time. I think they can hold for more than 20 seconds.Clever design, indeed. I've found that using plastic tweezers is the best solution, for me at least. Just make sure that the gripping ends of the tweezers have a texture that makes it easier to grab onto smooth surfaces. Regards, Jonathan RE: HP48GX RAM card design - arborist - 05-17-2021 04:50 PM (01-20-2021 10:25 PM)Jonathan Busby Wrote: Well, I have the Seiko-Epson official catalog of SRAM cards ( and other memory cards ) with all the technical specs, but, unfortunately, I've moved to Colorado from Texas and most of my possessions are in storage ATM. I scanned the catalog and I have it saved on an external HDD but it is in storage as well. I also wrote down, a long time ago, all the salient information regarding HP48GX compatible memory cards, but, it again is in storage :/ Thanks Paul and Wan for your work on this. Wan, would you consider sharing the KiCad (or at least Gerber) of your middle board? This is the most exciting HP48 project in a while! Jonathan, did you get access to your stuff? I would love to have this information. |
