home diff anomaly - Printable Version
+--- Thread: home diff anomaly (/thread-8521.html)
home diff anomaly - roadrunner - 06-17-2017 01:41 PM
In home type:
diff(X^(32/10),X)
you get:
(1/5)*(X^1/5)^(−4)*X^3+X^(1/5)*3*X^2
which, if you go thru the algebra, is correct. However, if you click on the answer and then click enter you get:
(1/5)*X^(1/5)^(−4)*X^3+X^(1/5)*3*X^2
on the command line which:
a. is incorrect, and;
b. not the same as the equation on line one of the stack.
The parenthesis is misplaced: X^(1/5)^-4 should be (X^1/5)^-4
This is on the emulator for PC, the handheld, and the free android app. Originally I thought only the handheld exhibited this behavior but just recently noticed it on the newer versions as well.
Here's a screen shot:
[attachment=4974]
-road
