EDM Slope Reduction - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: EDM Slope Reduction (/thread-8742.html) |
EDM Slope Reduction - Eddie W. Shore - 07-28-2017 10:18 PM The program EDMSLOPE calculates the following: * curvature correction due to the Earth * horizontal distance from observer to reflector at both elevation of the observer and at sea level * change of in elevation from observer to reflector Given: * slope distance between observer to reflector * height of both the observer and reflector’s instruments * the elevation the observer * zenith angle: angle from directly above to the slope distance line Notes: All measurements are given in feet. Assume that the correction factor due to light refraction is negligible. The radius of Earth is approximately 20,902,231 feet. Formulas (see diagram above) C = asin((90* sin Z * S)/(π * radius)) H = (S * sin(Z – C))/cos(Z) L = H * (radius / (radius + D)) E = (S * cos Z / cos C) + M – F HP Prime Program EDMSLOPE Code: EXPORT EDMSLOPE() Example Observer: D = 1,238.32 feet, instrument height = M = 3.5 feet Slope distance: S = 1,474 feet, at a zenith angle of 86.11° Reflector height = F = 3 feet Results: Curvature correction = C = 0.1154831691 Horizontal Distance-Elevation = H = 1,470.40255 ft Horizontal Distance-Sea Level = L = 1,470.315444 ft Elevation Change = E = 100.4980742 ft Sources: TI Programmable 58/59 Surveying – Texas Instruments 1977 |
