Debugger displays unevaluated expressions. - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Debugger displays unevaluated expressions. (/thread-881.html) |
Debugger displays unevaluated expressions. - Ben Fairbank - 03-10-2014 10:27 PM When I use Debug or MSGBOX() in the emulator to follow the value of variables in a program I am debugging, instead of values on the screen I see unevaluated expressions, such as: Maxheight2: 7.3894E-4/(1.0000/3.9600E3). Or (my favorite) height1 = 1.0000+FLOOR(5.0000+1.55O0e2*( 1.0000-2.2150e-9/(1.0000/3.9600E 3)/(7.3894E-4/(1.0000/3.9600E3)))+ 5.0000E-1) Needless to say, this gets tiresome very quickly and is not much of an aid to debugging. What am I missing? How do I get Debug and MSGBOX() to display values, not formulae? And as always, Thank You! Ben RE: Debugger displays unevaluated expressions. - Ben Fairbank - 03-10-2014 10:35 PM Aha. Just found how to use eval() to solve that. Thanks for the bandwidth. BF RE: Debugger displays unevaluated expressions. - DrD - 03-10-2014 10:39 PM Maxheight2: 7.3894E-4/(1.0000/3.9600E3). Or (my favorite) height1 = 1.0000+FLOOR(5.0000+1.55O0e2*( 1.0000-2.2150e-9/(1.0000/3.9600E 3)/(7.3894E-4/(1.0000/3.9600E3)))+ 5.0000E-1) if your code is using the "=" sign as above, try that again with ":=" like: height1:=1.0000+FLOOR(5.0000+1.55O0e2*(1.0000-2.2150e-9/(1.0000/3.9600E 3)/(7.3894E-4/(1.0000/3.9600E3)))+ 5.0000E-1); RE: Debugger displays unevaluated expressions. - cyrille de brébisson - 03-11-2014 06:17 AM Hello, It is strange that the numbers do not get evaluated by themselfves, you probably have a simple error somewhere that causes it. If you post your program code, I can have a look at it... note, do you know that there is a build in debuger? you can do debug(program) from the command line, OR you can add a debug instruction in your program to create a breakpoint. Cyrille |
