NumWorks open source calculator - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: NumWorks open source calculator (/thread-8931.html) |
RE: NumWorks open source calculator - StephenG1CMZ - 11-27-2021 09:42 PM (02-17-2021 10:50 PM)DA74254 Wrote:(02-15-2021 10:28 PM)StephenG1CMZ Wrote: Android: Can anyone suggest how to exit the calculator on Android. Tapping or holding the Numworks power switch does nothing (on the Numworks App).?? I have found that doing a pinch from the top and bottom of the screen (as if to make it smaller) brings up the three Android symbols (left arrow, circle and square) which can then be used. RE: NumWorks open source calculator - StephenG1CMZ - 05-15-2023 11:03 PM Google Play is telling me that Omega needs an older Android on my phone and Chromebook (Older than my Android 12). On an old phone (Android 8), Google Play says Omega is compatible but the install fails (as do most installs on that phone). Is it documented anywhere which Android Omega needs? (the online simulator only displays half the calculator). [Numworks epsilon is fine] RE: NumWorks open source calculator - cdmackay - 05-16-2023 04:31 PM Omega has refused to even start for me, for several years, so it must be quite an old version it needs. RE: NumWorks open source calculator - DA74254 - 05-17-2023 06:44 AM (05-16-2023 04:31 PM)cdmackay Wrote: Omega has refused to even start for me, for several years, so it must be quite an old version it needs. I'm running both Numworks and Omega fine with my Cat S62 Pro on Android 11. Omega run both in algebraic and RPN mode without issues. RE: NumWorks open source calculator - cdmackay - 05-17-2023 06:00 PM hmm, that's odd. I wonder what is wrong with my set-up? I uninstalled and reinstalled the app several times, before giving up. I still have Omega installed on my h/w Numworks, frozen in time of course since it is no longer being developed and the new Numworks OS no longer allow replacing the firmware (I believe). |
