(49G) OEIS A084545: Counting Base 5 without Zero - Printable Version
+--- Forum: General Software Library (/forum-13.html)
+--- Thread: (49G) OEIS A084545: Counting Base 5 without Zero (/thread-8947.html)
(49G) OEIS A084545: Counting Base 5 without Zero - Gerald H - 08-31-2017 03:07 PM
For integer input N the programme returns the Nth element of the sequence
https://oeis.org/A084545
NB The description below uses the expression
eg Z4_
for ZINT 4.
The two are however NOT the same, Z4_ having 2.5 Bytes & ZINT 4 having 6 Bytes.
The size & check sum below are for the version as printed.
  CK1&Dispatch
  # FF
    Z4_
    FPTR2 ^RMULText
    Z1_
    FPTR2 ^RADDext
    DUP
    FPTR2 ^Z>R
    %LN
    %5
    %LN
    %FLOOR
    %IP
    COERCESWAP
    Z5_
    3PICK
    FPTR2 ^RP#
    FPTR2 ^RSUBext
    NULL$
    ROT
    ZERO_DO
    OVER
    Z4_
    Z5_
    INDEX@
    FPTR2 ^RP#
    FPTR2 ^RMULText
    FPTR2 ^ZQUOText
    Z5_
    FPTR2 ^ZMod
    Z1_
    FPTR2 ^RADDext
    FPTR2 ^Z>S
    SWAP&$
    LOOP
    SWAPDROP
    FPTR2 ^S>Z
CKSUM # ADFFh
SIZE 149.5
RE: (49G) OEIS A084545: Counting Base 5 without Zero - Gerald H - 09-01-2017 03:57 PM
A faster version of the programme:
  CK1&Dispatch
  # FF
    Z1_
    SWAP
    Z4_
    FPTR2 ^RMULText
    Z1_
    FPTR2 ^RADDext
    DUP
    FPTR2 ^Z>R
    %LN
    %5
    %LN
    %FLOOR
    %IP
    COERCESWAP
    Z5_
    3PICK
    FPTR2 ^RP#
    FPTR2 ^RSUBext
    NULL$
    ROT
    ZERO_DO
    OVER
    4ROLL
    DUP
    Z5_
    FPTR2 ^RMULText
    5UNROLL
    Z4_
    FPTR2 ^RMULText
    FPTR2 ^ZQUOText
    Z5_
    FPTR2 ^ZMod
    Z1_
    FPTR2 ^RADDext
    FPTR2 ^Z>S
    SWAP&$
    LOOP
    ROTROT2DROP
    FPTR2 ^S>Z
RE: (49G) OEIS A084545: Counting Base 5 without Zero - Joe Horn - 09-01-2017 11:09 PM
If you use the standard HP extable library and 50g's built-in assembler, you can use Gerald's source code if you add the following lines to the very beginning:
EQU Z1_ 273B6
EQU Z4_ 273DA
EQU Z5_ 273E6
RE: (49G) OEIS A084545: Counting Base 5 without Zero - Gerald H - 09-03-2017 02:43 PM
But this programme is much faster & smaller:
CkSum: # 6A43h
  CK1&Dispatch
  # FF
    NULL$SWAP
    ZINT 5
    FPTR2 ^ZDIVext
    DUP
    ZINT 0
    EQUAL
    IT
      DROP
      ZINT 5
      SWAP
      ZINT 1
      FPTR2 ^RSUBext
      SWAP
    FPTR2 ^Z>S
    ROT
    &$SWAP
    DUP
    ZINT 0
    EQUAL
    UNTIL
    DROP
    FPTR2 ^S>Z
RE: (49G) OEIS A084545: Counting Base 5 without Zero - Eric Rechlin - 09-04-2017 07:16 PM
With that last version, I get 111.5 bytes and #DF96h, and it just hangs when I run it.
RE: (49G) OEIS A084545: Counting Base 5 without Zero - Gerald H - 09-04-2017 08:22 PM
I have copied the published programme & compiled on 50g, programme works correctly & size 110.5 & Cksum 6A43 as published above.
Has anyone besides Eric had problems?
RE: (49G) OEIS A084545: Counting Base 5 without Zero - Joe Horn - 09-04-2017 09:40 PM
(09-04-2017 08:22 PM)Gerald H Wrote:  I have copied the published programme & compiled on 50g, programme works correctly & size 110.5 & Cksum 6A43 as published above.
It runs fine on mine, and yields the size & checksum you cited. (It fails with inputs < -4 but that might be expected).
RE: (49G) OEIS A084545: Counting Base 5 without Zero - Eric Rechlin - 09-05-2017 01:08 AM
I take back what I said. This is a bug in Jazz. See my explanation on the other thread:
http://www.hpmuseum.org/forum/thread-8939-post-78579.html#pid78579
