Short hand for line feed (ppl)? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Short hand for line feed (ppl)? (/thread-895.html) |
Short hand for line feed (ppl)? - DrD - 03-13-2014 02:28 PM Print(char(10)); works ok, but is there a short hand notation that can be used or embedded in a print command for creating a new line? Something like "/n" for example. RE: Short hand for line feed (ppl)? - Han - 03-13-2014 02:57 PM You can use "\n" in some cases, but not all commands recognize "\n" RE: Short hand for line feed (ppl)? - patrice - 03-13-2014 04:55 PM Each PRINT is on a new line already. So to have a blank line PRINT(""); Should do what you want. RE: Short hand for line feed (ppl)? - DrD - 03-13-2014 07:30 PM Neither \n nor the "" approach seem to work when concatenated with additional info within a print command. (Something along these lines): print( "something" + var +<some kind of newline shorthand> + "something else"); RE: Short hand for line feed (ppl)? - patrice - 03-13-2014 07:54 PM (03-13-2014 07:30 PM)DrD Wrote: Neither \n nor the "" approach seem to work when concatenated with additional info within a print command. (Something along these lines):PRINT is pretty limited, so the easiest way is: Code: print( "something" + var ); RE: Short hand for line feed (ppl)? - eried - 03-13-2014 08:25 PM (03-13-2014 07:54 PM)patrice Wrote: PRINT is pretty limited, so the easiest way is:Pretty limited for what? for drawing? for calculating? ![]() Code: PRINT("Hello"+CHAR(10)+"World"); RE: Short hand for line feed (ppl)? - Han - 03-13-2014 09:10 PM (03-13-2014 08:25 PM)eried Wrote:(03-13-2014 07:54 PM)patrice Wrote: PRINT is pretty limited, so the easiest way is:Pretty limited for what? for drawing? for calculating? If we want something like "\n" for repeated use, and prefer to not have to repeatedly type CHAR(10), perhaps the following may be useful: Code:
Any future use of print that requires a newline character can simply use nl in place of char(10) -- smaller source file and less typing. RE: Short hand for line feed (ppl)? - eried - 03-13-2014 09:26 PM You can press enter too :O Code: PRINT("Hello or Code: PRINT("Hello"+" RE: Short hand for line feed (ppl)? - DrD - 03-14-2014 12:59 AM I like the idea of creating a variable to hold the new line string. That solution seems to produce all the desirable features I was after, and helps keep the program structure nice and tidy. Thank for that idea! -Dale- |
