Post Hoc test on the HP prime - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Post Hoc test on the HP prime (/thread-8987.html) |
Post Hoc test on the HP prime - pr011235 - 09-05-2017 01:36 PM Does anyone know of a program or technique that will allow you to perform a post hoc analysis like Tukey Kramer or Scheffé's test on the HP Prime. RE: Post Hoc test on the HP prime - webmasterpdx - 09-05-2017 11:04 PM I'm sure you could take data in from one of the statistical analysis apps, copy the app and personalize it adding your own code to do whatever form of analysis you want....including any kind of plotting you like. Good luck and remember to post your app online so others can use it too. -Donald |
