STO+ adds to front of string, not end - Printable Version
+--- Thread: STO+ adds to front of string, not end (/thread-9154.html)
STO+ adds to front of string, not end - brickviking - 09-25-2017 09:14 AM
From the entry line, doing the following combines two strings properly.
"ABC" "DEF" +
I decided I wanted to stuff these into a variable and add the second bit manually, except I came up against a small problem.
"ABC" 'J' STO+ @results in the following and an error box:
2: "ABC"
1: 'J'
ErrorBox("STO+ Error", Undefined Name)
So obviously STO+ relies on the variable being initialised already. Fair enough, though I haven't found it mentioned explicitly (yet).
Once I created the variable J I tried this:
"ABC" 'J' STO+ @results in "ABC"
"DEF" 'J' STO+ @results in "DEFABC"
Why is this? Or do I just have something wrong here? I'm mainly using the AUR at the moment, as I don't have the other two documents (UM/UG) in hard-copy, only in PDF.
(Note): This is related to a program I'll post in another thread.
(Post 96)
RE: STO+ adds to front of string, not end - Gilles59 - 09-25-2017 09:24 AM
Hi
Try 'J' "DEF" STO+
RE: STO+ adds to front of string, not end - pier4r - 09-25-2017 09:49 AM
(09-25-2017 09:24 AM)Gilles59 Wrote:  Hi
Try 'J' "DEF" STO+
same with list. STO<op> is pretty flexible.
